2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum 140010 - Combustion misfire, several cylinders
      11-30-2024, 03:12 PM   #1
Bertiljn
Bertiljn's Avatar
Drives: BMW 535i F10 2010 model
2011 535i  [0.00]
Hi.
I get the following error code:
"140010 - Combustion misfire, several cylinders".
It varies which cylinders I get the error code on.
I have received a factory recall to fix a fault in the "VANOS" system.
Could "VANOS" be the cause of the "Misfire"?
      11-30-2024, 08:40 PM   #2
ChiltiCoatl89
ChiltiCoatl89's Avatar
Drives: 2016 F10 BMW 535i M Sport
Process of elimination, yes, get that taken care of ASAP!
      12-03-2024, 03:27 PM   #3
Bertiljn
Bertiljn's Avatar
2011 535i  [0.00]
Replaced all spark plugs and coils, and problem solved. Suspect spark plug/coil for cylinder 6, as this plug was wet.
      01-12-2025, 03:50 AM   #4
Bertiljn
Bertiljn's Avatar
2011 535i  [0.00]
Factory re-call and replacing of spark plugs and coils, didn`t solve the problem. Next step is to change all of the injectors. If that doesn`t help; change of HPFP?
