2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications Beta testing the new VRSF Turbo Inlet and install
      08-28-2019, 09:27 PM   #1
Carlbalzer
Drives: 2012 bmw 535xi
Post Beta testing the new VRSF Turbo Inlet and install
*I'm going to preface this by letting you know that I was chose to test the first ever VRSF Turbo Inlet for the N55 F10. Since this inlet has not been officially released yet, I can not share the pictures of it. Once Tiago and VRSF does their official release, I will update with my pictures.*
Test car - 2012 BMW 535ix FBO, Pure Stage 2 Turbo on the conservative 93 tune of about 20psi. With a leaking valvecover gasket it now looks like That will be fixed next.
The results: These are done within 2 hours of each other and with nothing done to the tune. Just swapping the inlet.
Before: Peaking at 21psi and tapering to 15psi.
After: Peaking at 24psi and tapering to 19psi.
What a difference this inlet has made already!!!!! An extra 4psi till redline and a much better response. I'm sure i will be able to pick up a few more once we revise the tune and i upgrade to a larger filter. This is a definite must have part for all N55 F10 owners!!
The Install:
This can be done without the use of a lift of jackstands.
1. Remove your intake system down to the inlet.
2. Remove your stiffening bars and radiator fan so you can have better access to the inlet.
3. Remove the clip to your boost pipe so you can slide the pipe up an off to the left of the turbo to allow more room to work.
4. Remove the top 10mm bolt on your factory inlet.
5. Remove the 10mm bolt holding your inlet to the turbo. This one is pretty hard to get to and i had to use a few extensions to get to it and go through the front.
6.Gently wiggle your inlet and remove it from your engine. Be careful not to snag any lines as you pull it out.
7. Swap your bolt bushing from your factory inlet onto your new vrsf inlet.
8. Install your new vrsf inlet the same way you took your factory inlet out.
9. Install your intake.
10. Install your support brace and radiator fan.
That pretty much sums it up. Just take your time and be careful. It took me about an hour, learning as i went. I can't give a detailed install until the official release of the product.
I hope this helps!!!
      09-02-2019, 07:14 PM   #2
hardparker
BMX3er
227
Drives: Yo daddy's 2014 X3 M Sport
2013 BMW X1  [0.00]
2014 BMW X3  [0.00]
Any more about this? FTP has a version now, too.
F25 X3 35i M Sport | VRSF Race IC | FTP CP | BM3 tuned | XDI-35 HPFP | Stage 2 LPFP | Ethanol mixed | WMI | Oil cooler | xHP | X5/550i brakes
      09-03-2019, 02:42 AM   #3
doodlebro
Drives: '17 X3 35i
Careful, the non-turbo side of the inlet on F10's is SLIGHTLY larger diameter than it is on our cars. I basically have the entire clean air pipe/inlet from an F10 now as I'm using AZMCRacer's custom inlet he had made. Made for an interesting back and forth between FCPEuro, my shop, and myself to track it down.
Current mods
Rockford Fosgate P3 // JBL MS-A5001 // MiniDSP
AFe Pro Dry S // PS2 // Custom Inlet // DV+ // FTP Boost Pipes // VRSF 5" FMIC // VRSF Downpipe // BM3 Stage 2 91 @ 5280'
      09-06-2019, 12:41 PM   #4
byebyev8
Drives: e92 335i f10 535i msport
Wounder if there would be a similar effect on the stock turbo?
tet0010.00
      09-06-2019, 01:24 PM   #5
ziekxq
Drives: 2011 535i xDrive
Stock turbo won't gain any benefit from this.
      09-06-2019, 01:27 PM   #6
ziekxq
Who is your tuner? Also, what spark plugs and gap you running? Just in 93 Oct 24 peak and 20 to redline is really good. Maybe I need to invest into those coils.
      09-08-2019, 05:01 PM   #7
bigscore
Drives: BMW F10 coming soon
Would a stage 1 Pure benefit from this inlet ?
      09-23-2019, 01:37 AM   #8
Bmw doubles
Dream crusher
Bmw doubles's Avatar
Drives: Fast
2011 535  [0.00]
Nice write up. An extra 4psi up top is a big deal!
IG: @bmwdoubles
      10-03-2019, 03:10 PM   #9
mike@x-ph.com
Joint Chiefs of Staff
mike@x-ph.com's Avatar
Drives: 2007 e92 335i / 2013 F30 328
      10-22-2019, 12:18 PM   #10
jooobi3
jooobi3's Avatar
Drives: 2011 BMW 535i XDrive
Any updates?
      10-23-2019, 12:01 PM   #11
Bmw doubles
Dream crusher
Drives: Fast
2011 535  [0.00]
Not trying to be a Debbie-downer more of an FYI. Be careful on running high boost on the stock piping to intercooler, hot side with a stock turbo.
Not sure what the melting temp is on the OEM plastic but here's what happened to my turbo outlet hot side. I was running 19psi with a DP and obviously for me that was not enough to purge the scorching temps. I'm sure the turbo was glowing red at times.
Why you should change out the hot side pipe to aluminum https://f10.5post.com/forums/showthread.php?t=1662631
This could be a unique case for me however I discovered this recently when refreshing all of my seals.
Happy pumpkin spice boost season 👻 🎃 🐌 💨
IG: @bmwdoubles
jooobi354.50
Tags
535, f10, inlet, install 5, vrsf
Copyright ©2000 - 2020, vBulletin Solutions Inc.
