2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications 2011 bmw
      09-17-2019, 08:40 PM   #1
Lrobinson
Drives: 2011 bmw 535i
Angry 2011 bmw
I have 2011 bmw 535i I am trying to see if this the crank sensor or something else here is the codes 101f01 and 102002 please help me
      09-17-2019, 09:10 PM   #2
BurrNinja
Was showing two things for code 101f01.
Throttle valve opening angle - intake pipe absolute pressure, comparison Pressure too high
or
Air mass system, plausibility: calculated air volumes in air intake system implausible.
For other code.
Air volume, plausibility: Air volume to low.
All pulled from
http://bmwfault.codes/
Instgram @burninja
      10-28-2020, 01:04 PM   #3
coolmellowdude
Drives: NA
Have the same issue. After vehicle warms up, it begins to loose power.
101F01 - Air mass system, plausibility; calculated air masses in the air intake system not plausible.
102001 - Air mass system, plausibility; Air mass too high
People online suggest replacing Vanos Solenoid, and Intake Air Temperature sensor/s. I believe I have (2).
