2010 2011 BMW 5 Series Forum F10 BMW 550i F07 LSD(limited slip differentail) and Carbon Fiber Driveshaft |
07-04-2016, 11:08 PM | #1 |
Rep 20
I'm going to be maybe the 1st to install an LSD in to my 550i GT and also getting a custom made Carbon Fiber Driveshaft for my 550i GT with these two upgrades I'll be able to put down more HP and TQ I know this for a fact I've researched this a lot I've already purchased all the components just wAiting for things to come in
On the Road to getting 600whp and 600wtq http://www.birdsauto.com/quaife/sear...373&mi=550i+GT They also have 550i F10 available I think it's a no brainer 2wheels is always better than 1wheel Don't need any opinions about this and that with LSD and Carbon Fiber driveshaft these upgrades are very beneficial I actually went to the UK to ask questions and test drive a 550i with LSD Damn this car is fast (stock) it's a night and day difference |
07-04-2016, 11:45 PM | #2 |
Rep 14,521
so why post if you don't want any opinions
07-05-2016, 08:27 AM | #3 |
Rep 738
Meh Im honestly not wasting my time with my N63, now if it was a TU then yea.
I do like that idea of the LSD, Id love to try one out.
2011 550i
2013 M5 2014 M5 CP 2016 550i |
07-05-2016, 04:29 PM | #4 |
Rep 20
07-05-2016, 04:34 PM | #5 |
Rep 14,521
07-06-2016, 06:21 PM | #7 |
Rep 163
With an LSD and carbon fiber driveshaft you shouldn't be putting down a more noticeable amount of power. With the driveshaft you are reducing the mass of the shaft so you might gain a little there, but the LSD will only change your power delivery, not increase power.
If you get a shorter ratio than stock you will feel an increase in acceleration, but you will be cruising at a higher RPM in your max gear. However, the car will corner much better and accelerate much smoother if you lose traction. And you can rip sweet burnouts. But don't get your hopes up for power.
07-06-2016, 07:34 PM | #8 |
Rep 14,521
07-06-2016, 08:00 PM | #9 | |
Rep 20
Before and After and the after results were amazing so having a LSD and carbon fiber driveshaft is a big benefit from what I saw while the 550i was being tested with the components installed |
07-06-2016, 09:24 PM | #10 |
Rep 1,214
The only way you'll see a "power gain" on a dyno by installing an LSD is if you change to a shorter gear ratio and thus multiply torque to the wheels in the process.
Isn't the factory driveshaft aluminum? I can't imagine the carbon fiber one being enough lighter to feel any difference. Yes it is rotational mass but the rotational radius is short.... |
07-06-2016, 09:30 PM | #11 | |
Rep 20
07-06-2016, 10:50 PM | #12 |
Rep 1,214
It not an opinion when you actually know what you're talking about. I work on BMW's for a living, I've spent the last ~18 years doing so.
There will be absolutely no difference in straight line acceleration with the simple addition of an LSD over an open diff. The only way you're going to accelerate faster is the initial off the line from a stand still burst -IF- you were blowing the tires off with the open diff, and the LSD allows you to find traction. All other things equal an LSD doesn't make the car any faster to accelerate once you're moving. One might argue that the rotating mass of the LSD is actually significantly heavier than the open diff too... How many LSD's have you built? I've built & installed dozens. Again, facts not opinions here. |
07-06-2016, 11:04 PM | #13 | |
Rep 20
07-06-2016, 11:28 PM | #14 |
Rep 1,214
Not just installed, but built.... again how many LSD's have you torn down and put back together? Do you understand how they work? If you did you're know why there are no magical power gains or acceleration gains from them.
Manipulating dynometer data is fundamentally simple. Ask any dyno operator, they will tell you how simply data can be skewed. There are no ruffled panties in my house, I prefer lace. That said I'm just trying to offer you some wisdom. Accept it if you will or just disregard and blow your money. Either way it doesn't affect me. |
07-07-2016, 06:56 AM | #15 | |
Rep 998
^^^ Agree...
You should take those dyno's with the grain of salt. Were the dyno runs done at the same day, same conditions, same parameters? I have seen dyno runs of the same car under the same conditions and minutes from each other (with proper cool down) but with 4-6% gain or loss. Force induction cars can be tricky at the dyno and if you know what you are doing it can be pretty easy to manipulate with things to achieve desired results. Quote:
07-07-2016, 09:17 AM | #16 | |
Rep 20
07-07-2016, 10:30 AM | #18 | |
Rep 998
No problem. If I were you , I would start with getting light-weight wheels (such as Apex ARC-8) and some nice sticky non-run flat tires. You will improve your MPGs, acceleration and ride guaranteed. Also, because of the radius of rotational mass, upgrading to light-weight wheels and tires is more beneficial than getting a light-weight driveshaft.
. Last edited by Sedoy; 07-07-2016 at 10:36 AM.. |
07-08-2016, 10:08 AM | #19 | ||
Rep 20
07-09-2016, 02:20 PM | #20 | |
Rep 2,416
07-09-2016, 03:26 PM | #21 | |
Rep 998
07-09-2016, 03:52 PM | #22 | |
Rep 2,416
