2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum Headlight condensation
      09-05-2017, 08:28 PM   #1
TJBentley
TJBentley's Avatar
Drives: '12 528xdrive
Been noticing this condensation lately in my drivers side headlight for the past week. Did some research, a small amount is supposed to be "normal" but what do you guys think is this normal?? Doesn't look like it to me
      09-05-2017, 08:29 PM   #2
TJBentley
TJBentley's Avatar
You can't really tell in the pic but it's also in the white eyebrow area of the headlight
      09-06-2017, 11:21 AM   #3
snj1013
Drives: 2011 528i
I've never noticed condensation in my F10's headlights and I've owned the car for over 6 years. I'd remove the bulb and let it dry out and inspect the cover to see if the gasket/o-ring looks cracked. Put it back together and see if the problem comes back.
      09-07-2017, 08:15 AM   #4
TJBentley
TJBentley's Avatar
Good advice I'm going to do that, thanks. Car is 5 years old now never had a problem before with the headlights but first time for everything I guess
      09-07-2017, 10:24 AM   #5
EL Jeffe 5
EL Jeffe 5's Avatar
Drives: CBR1000RR
Friend of my had same issue when he took car to dealer he was told it wasn't OEM headlight.
I guess car was in accident and somebody install aftermarket headlight.
      09-07-2017, 02:56 PM   #6
DaHeadlightGuy
Drives: 2013 DSB F10
Drop a couple of Silica packs inside the light it will help keep the condensation down.
I use these when i build a set of retrofitted lights.
https://www.amazon.com/10-Gram-Premi...ca+gel+packets
TJBentley135.00
      09-07-2017, 06:06 PM   #7
TJBentley
TJBentley's Avatar
Sucks for your friend if he didn't know it was aftermarket
      09-07-2017, 06:07 PM   #8
TJBentley
TJBentley's Avatar
Thanks I will def give it a try. So take out the headlight bulb and drop it in through there. How would I retrieve them
      09-07-2017, 07:42 PM   #9
wcr3d
Drives: 2013 535i XDrive M Sport
I wouldn't want that in my headlights.
Did you ever check the seals on the covers?
      09-08-2017, 10:32 AM   #10
EL Jeffe 5
EL Jeffe 5's Avatar
Drives: CBR1000RR
Chance we take when buying used car yeah it sucks
Headlight is about $2k?
      09-08-2017, 11:06 AM   #11
TJBentley
TJBentley's Avatar
Yup just about brand new. I got a quote from a place to fix it for $350. Does this sound fair to everyone? Includes bumper removal and reinstall, remove old glue, and reseal
      09-08-2017, 11:50 AM   #12
DaHeadlightGuy
I put them inside the covers. so remove the cover and lay it down so it is like a bowl. and i will add a little superglue to the ends of the silica packets then lay them down on the inside, then reinstall the cap. The corner lamp cap is the easiest to get to and it. But i would put 1 on the corner lamp, and 2 on the backside of the projector cover.
Best to run the headlights all the time while driving for a while and the heat should evaporate the condensation to the silica packets.
TJBentley135.00
      09-08-2017, 02:19 PM   #13
EL Jeffe 5
EL Jeffe 5's Avatar
Drives: CBR1000RR
I say its fair as long they guarantee work they do, because I would hate to drop $350 and next time you wash your car you get in same situation.
TJBentley135.00
      09-09-2017, 07:41 AM   #14
TJBentley
TJBentley's Avatar
Thanks I'm going to try this first since it's the cheapest method. I can get to the covers from the wheel well correct?
      09-10-2017, 01:32 PM   #15
EL Jeffe 5
EL Jeffe 5's Avatar
Drives: CBR1000RR
yes
      01-24-2020, 10:36 PM   #16
David_Vasha
David_Vasha's Avatar
Drives: 2011 535i XDrive
Has anyone just put like a super glue sealant around the sealant area in which the seal was broken? Just thinking that since the whole deal isn't broken I could just seal the damaged area and not worry about the headlight not being able to ventilate.
