08-07-2024, 01:31 AM | #67 | |
![]() 781
Rep 1,081
Here is your favorite type....$70, and it comes with the rear connector.. https://www.ebay.com/itm/28525861584...Bk9SR8zn-bSlZA |
08-09-2024, 07:33 PM | #68 | |
![]() 1410
Rep 2,651
That said, I'm like 99% sure the actual brains of the control units are the same for non-heated, heated, and heated+cooled seats. It's just the button set that is different. You could, in theory, buy a basic control unit and then just buy BMW's button repair set that is applicable for your car. Haven't been able to verify this theory, however.
2015 BMW 535xi
08-11-2024, 03:57 AM | #69 |
![]() ![]() 152
Rep 153
This is for screen and temperature sensors wiring, the other one is sensors inside air vents and light for knobs and 12V socket has its own wires. I don't know exact wiring, i was replacing my air vents and temp knobs recently as some kid probably kicked it with foot so i wa not bothered which wire goes where, just plug out and plug in. I bought a car with rear climate.
08-18-2024, 12:11 AM | #70 | |
![]() 29
Rep 152
Why cant you buy the parts new from the bmw dealership? |
08-30-2024, 11:49 PM | #71 | |
![]() 29
Rep 152
For these 4 parts, can you buy them new at the bmw dealership and install them? - 64119290824 4-zone Distribution housing, upper (qty 1) - 64119241198 4-zone Distribution housing, lower (qty 1) - 64119166109 4-zone Distribution housing, temp sensor (+2 more required) - 64118319037 4-zone Distribution housing, actuators (+5 more required) Also, i cant seem to find Part # 64118319037 online, is that the right part number? I was thinking about doing this but with new parts, do you know if the parts above come with the wiring harnesses needed? |
08-31-2024, 12:17 AM | #72 | |
![]() 781
Rep 1,081
Typically most get the whole air distribution box from eBay with the wiring harness and all actuators (P/N 64118319037) in one assembly for a few hundred dollars. But to answer your question, all BMW Part Numbers listed for this retrofit can be purchased directly from your BMW dealership. |
Tags |
climate control, f10 |
