2010 2011 BMW 5 Series Forum F10 So many questions about wheels/tire |
05-10-2020, 05:18 PM | #1 |
Rep 17
Drives: BMW 535i xdrive
So, I would consider myself a self proclaimed wheel/tire moron. I've done a decent bit of research, but apparently I'm just dumb when it comes to wheels. So I have a handful of questions I'm hoping you guys could help me out with.
All of my questions refer to my 2016 535i xdrive m sport right now they are 19x8.5 all the way around with a +33 offset. 1. I'm looking into getting 20inch wheels to use as summer wheels instead of my stock 19 inch wheels. Problem is, wouldn't this throw off my speedometer? And if so, how would 8 fix that? 2. Since my car is xdrive, would it be best to go with a square setup over say 20x9 front and 20x10 in back? Or should that not really be a concern? 3. Would going to a +40 offset be too far off spec? My stock wheels are +33. There are probably more questions, but I can't think of them right now. Thanks in advance guys! |
05-10-2020, 10:22 PM | #2 |
Rep 2,590
1. Assuming you're not going for a massively different spec, it's so small it won't matter. If you're really that concerned, get a GPS speed app for your phone (google maps and waze have this by default)
2. The only concern is tire rotation with staggered. Staggered is fine as long as the total diameter of the front and back wheels are within 1%, per BMW's specs 3. You'd be moving the wheel 7mm in. Are you sure about this offset? I don't really see folks go LESS aggressive than stock tbh.
2015 BMW 535xi
05-11-2020, 10:00 AM | #3 | |
Rep 17
From the specs I have on my car, I have a 33 offzet with the stock performance 19in wheels. Most of the 20in wheels i have been looking at are 35-40 for the offest. maybe because I am looking at 9-10 width, while my stocks are 8.5? |
05-11-2020, 11:17 AM | #4 | |
Rep 2,590
Ah, wasn't aware you were changing width, thought you were only upsizing. Not 100% sure on the offsets, remmib is usually the go to for this
2015 BMW 535xi
05-11-2020, 11:26 AM | #5 | |
Rep 17
Thanks for the contact! |
05-11-2020, 02:52 PM | #6 |
Rep 29,202
Going with a 245/35/20 will keep the wheel diameter the same as your 19s, so it wouldn't through off the speedometer.
Offsets; I wouldn't go higher than ET35 on a 20x9 wheel.
