02-15-2023, 11:02 AM | #1 |
Rep 3
2011 bmw 550i
Trying to replace downpipes I believe they are a 2 bolt flange connection. It has a bracket at the bottom of the stock down pipe that is connected to what seems the starter? How do I get this off?
02-16-2023, 01:08 AM | #2 |
Rep 263
I think I used a set of flex ratchet box wrenches and also a 3/8” or 1/2” adjustable head ratchet drive and short sockets. It wasn’t too bad from I remember, it was tight in there but not bad. Use some PB blaster on the bolt/nut too. Good luck!!
2011 550i (N63)
Upgraded 51mm turbos, Heatsync Stage 3 Flash, JB4 stacked, BMS WMI, Arm Charge Pipes, Heatsync Catless DPs, X-Pipe, Res Muffler Delete, xHP Stage 3 Trans Flash, Turbosmart Diverter Valves, 3.5 TMAPs, Oil Cooler, Heatsync Front Mounted Max Cool Intakes, Walbro LPFP and e40 mix rollin on Stance SF07 9x20 w/Toyo Extensa and 10.5x20 w/Toyo R888R. |
eltaco550i0.00 |
02-18-2023, 01:59 PM | #4 |
Rep 263
I honestly don’t remember because it’s been so long but I want to say there was a stupid bracket I had to remove. None of the guides online show removing it or it even being there, sorry I’m not much more help. Do you have a pic, maybe that jogs my or someone elses memory?
2011 550i (N63)
