BMW 3-Series (E90 E92) Forum
How much SHOULD this cost?
03-20-2019, 02:08 AM | #1 |
Rep 6
Brought my '07 335I coupe into the dealership to get the fuel pump replaced under the extended warranty...... This is what they came back with. How much should this cost realistically at an independent mechanic? Any other thoughts? Help.....
CUSTOMER QUOTE __________________________________________________ ______________________________ OPERATION: 1351518 Fuel Pump, r&r 335i/335xi 07/10 Engine Bay QTY PART NUMBER PART DESCRIPTION PART PRICE EXT PRICE 1 BM13-51-7-616-446 EXCH HIGH-PRESSURE P 299.97 299.97 1 BM11-61-7-547-242 SET OF PROFILE GASKE 37.56 37.56 LABOR $: 538.02 PARTS $: 337.53 GOG $: 0.00 MISC. $: 0.00 TAX $: 27.85 ------------------------ SUBTOTAL $: 903.40 -------------------------------------------------------------------------------- OPERATION: BR-322 FRONT BRAKES AT 2MM. RECOMMEND IMMEDIATELY. 335i 2007 Up To 2-07 QTY PART NUMBER PART DESCRIPTION PART PRICE EXT PRICE 1 BM34-11-6-794-917 REPAIR KIT, BRAKE PA 163.28 163.28 1 BM34-35-6-789-440 BRAKE PAD WEAR SENSO 23.27 23.27 1 BM83-12-2-296-187 BRAKE PAD PASTE - 5 1.30 1.30 2 BM34-11-6-855-000 BRAKE DISC, VENTILAT 183.29 366.58 1 BM34-35-6-779-356 CLIP FOR BRAKE PAD W 1.17 1.17 1 ZLBULKBC2 BULK BRAKE CLNR 2.75 2.75 LABOR $: 246.79 PARTS $: 558.35 GOG $: 0.00 MISC. $: 0.00 TAX $: 46.06 ------------------------ SUBTOTAL $: 851.20 -------------------------------------------------------------------------------- OPERATION: BR-321 REAR BRAKES AT 1MM. ALMOST METAL ON METAL 330i/335i 06/09 QTY PART NUMBER PART DESCRIPTION PART PRICE EXT PRICE 1 BM34-21-6-791-938 REPAIR KIT, BRAKE PA 110.65 110.65 1 BM34-35-6-789-445 BRAKE PAD WEAR SENSO 24.42 24.42 2 BM34-21-6-855-004 BRAKE DISC, VENTILAT 150.24 300.48 1 BM83-12-2-296-187 BRAKE PAD PASTE - 5 1.30 1.30 1 ZLBULKBC2 BULK BRAKE CLNR 2.75 2.75 LABOR $: 246.79 PARTS $: 439.60 GOG $: 0.00 MISC. $: 0.00 TAX $: 36.27 ------------------------ SUBTOTAL $: 722.66 -------------------------------------------------------------------------------- OPERATION: OILSER6 Oil Service OEM 335i/335is 07/13 QTY PART NUMBER PART DESCRIPTION PART PRICE EXT PRICE 1 BM11-42-7-566-327 SET OIL-FILTER ELEME 9.92 9.92 7 BM07-51-0-017-954 MOTOR OIL SAE 5W-30 7.44 52.08 MISC CODE MISC DESCRIPTION QUOTE MIN QUOTE MAX PRICE HW HAZARDOUS WASTE 3.00 LABOR $: 29.83 PARTS $: 62.00 GOG $: 0.00 MISC. $: 3.00 TAX $: 5.12 ------------------------ SUBTOTAL $: 99.95 -------------------------------------------------------------------------------- OPERATION: FBS BRAKE FLUSH - SHOWS DUE PER CBS. VERY LOW/DIRTY. All QTY PART NUMBER PART DESCRIPTION PART PRICE EXT PRICE 2 BM81-22-0-142-156 BRAKE FLUID 10.37 20.74 MISC CODE MISC DESCRIPTION QUOTE MIN QUOTE MAX PRICE HW HAZARDOUS WASTE 6.00 LABOR $: 110.50 PARTS $: 20.74 GOG $: 0.00 MISC. $: 6.00 TAX $: 1.71 ------------------------ SUBTOTAL $: 138.95 -------------------------------------------------------------------------------- OPERATION: MSPR6 REPLACE SPARK PLUGS - DUE AT 45K. 335i/335is 07/13 QTY PART NUMBER PART DESCRIPTION PART PRICE EXT PRICE 6 BM12-12-0-037-244 SPARK PLUG, HIGH POW 31.58 189.48 LABOR $: 234.32 PARTS $: 189.48 GOG $: 0.00 MISC. $: 0.00 TAX $: 15.63 ------------------------ SUBTOTAL $: 439.43 -------------------------------------------------------------------------------- OPERATION: ACMF REPLACE MICROFILTER - SHOWS DUE 2012 335i/335is/335xi 07/13 Activated Charcoal MF QTY PART NUMBER PART DESCRIPTION PART PRICE EXT PRICE 1 BM64-31-9-313-519 MICROFILTER/ACTIVATE 68.74 68.74 LABOR $: 68.75 PARTS $: 68.74 GOG $: 0.00 MISC. $: 0.00 TAX $: 5.67 ------------------------ SUBTOTAL $: 143.16 -------------------------------------------------------------------------------- OPERATION: BR-323 REPLACE ALL 4 PADS/ROTORS/BOTH SENSORS 335i 2007 Up To 2-07 QTY PART NUMBER PART DESCRIPTION PART PRICE EXT PRICE 1 BM34-11-6-794-917 REPAIR KIT, BRAKE PA 163.28 163.28 1 BM34-35-6-789-440 BRAKE PAD WEAR SENSO 23.27 23.27 2 BM83-12-2-296-187 BRAKE PAD PASTE - 5 1.30 2.60 1 BM34-21-6-791-938 REPAIR KIT, BRAKE PA 110.65 110.65 1 BM34-35-6-789-445 BRAKE PAD WEAR SENSO 24.42 24.42 2 BM34-11-6-855-000 BRAKE DISC, VENTILAT 183.29 366.58 2 BM34-21-6-855-004 BRAKE DISC, VENTILAT 150.24 300.48 1 BM34-35-6-779-356 CLIP FOR BRAKE PAD W 1.17 1.17 1 ZLBULKBC2 BULK BRAKE CLNR 2.75 2.75 LABOR $: 495.56 PARTS $: 995.20 GOG $: 0.00 MISC. $: 0.00 TAX $: 82.10 ------------------------ SUBTOTAL $: 1572.86 -------------------------------------------------------------------------------- OPERATION: 17TIRE2 REAR TIRES 1MM FROM WEAR BARS ON INSIDE. 335 Continental ProContact SSR 225/45R17 91H Two QTY PART NUMBER PART DESCRIPTION PART PRICE EXT PRICE 2 BM36-11-0-414-665 TIRE 225/45R17 CONTI 252.94 505.88 2 BM36-12-1-116-326 RUBBER VALVE 9.20 18.40 2 ZLSS29 TAPED WEIGHTS 5.00 10.00 LABOR $: 50.00 PARTS $: 534.28 GOG $: 0.00 MISC. $: 0.00 TAX $: 44.08 ------------------------ SUBTOTAL $: 628.36 -------------------------------------------------------------------------------- OPERATION: AL4WD RECOMMEND ALIGNMENT WITH REAR TIRES. AFTERMARKET WHEELS WILL REQUIRE SPECIAL ADAPTERS AND INCREASED RATE. LABOR $: 209.95 PARTS $: 0.00 GOG $: 0.00 MISC. $: 0.00 TAX $: 0.00 ------------------------ SUBTOTAL $: 209.95 -------------------------------------------------------------------------------- OPERATION: 2434021 TRANSMISSION SEALING SLEEVE HEAVY LEAK ZF Exc 335d 06/13 QTY PART NUMBER PART DESCRIPTION PART PRICE EXT PRICE 1 BM24-34-7-588-725 SEALING SLEEVE 29.60 29.60 1 BM24-11-7-571-235 GASKET, OIL PAN 45.38 45.38 1 BM24-11-7-520-714 O-RING 9.20 9.20 3 BM83-22-0-406-929 1/2 LITER OIL 25.00 75.00 1 BM24-11-7-520-713 SCREW PLUG 14.49 14.49 LABOR $: 512.02 PARTS $: 173.67 GOG $: 0.00 MISC. $: 0.00 TAX $: 14.33 ------------------------ SUBTOTAL $: 700.02 -------------------------------------------------------------------------------- OPERATION: 3112148 THRUST ROD BUSHINGS LEAKED OUT 325i/328i/330i/335i/335is 06/13 Both QTY PART NUMBER PART DESCRIPTION PART PRICE EXT PRICE 2 BM31-12-6-763-719 HYDROBEARING 71.68 143.36 2 BM33-30-6-787-062 COMBINATION NUT 8.52 17.04 2 BM31-10-6-767-496 LOCKING NUT 9.88 19.76 LABOR $: 345.13 PARTS $: 180.16 GOG $: 0.00 MISC. $: 0.00 TAX $: 14.86 ------------------------ SUBTOTAL $: 540.15 -------------------------------------------------------------------------------- OPERATION: 1142021G OIL FILTER HOUSING GASKET LEAKING 335i/335xi 07/10 A/T W/ Sport Package QTY PART NUMBER PART DESCRIPTION PART PRICE EXT PRICE 1 BM11-42-7-537-293 GASKET 25.20 25.20 1 BM11-42-7-525-335 GASKET 25.20 25.20 1 BM11-61-7-547-242 SET OF PROFILE GASKE 37.56 37.56 LABOR $: 832.14 PARTS $: 87.96 GOG $: 0.00 MISC. $: 0.00 TAX $: 7.26 ------------------------ SUBTOTAL $: 927.36 -------------------------------------------------------------------------------- OPERATION: 3133002 REPLACE BOTH FRONT STRUTS. L/F LEAKING HEAVY. R/F STARTIN 328i/335i/335is 07/13 Sport Suspension Both QTY PART NUMBER PART DESCRIPTION PART PRICE EXT PRICE 2 BM31-30-6-775-098 GUIDE SUPPORT 160.58 321.16 6 BM31-31-6-769-731 SELF-LOCKING COLLAR 3.10 18.60 2 BM33-32-6-760-668 SELF-LOCKING COLLAR 4.08 8.16 1 BM31-31-6-786-003 LEFT FRONT SPRING ST 340.28 340.28 1 BM31-31-6-786-004 FRONT RIGHT SPRING S 340.28 340.28 2 BM31-33-6-767-333 ADDITIONAL SHOCK ABS 37.15 74.30 LABOR $: 749.80 PARTS $: 1102.78 GOG $: 0.00 MISC. $: 0.00 TAX $: 90.98 ------------------------ SUBTOTAL $: 1943.56 -------------------------------------------------------------------------------- OPERATION: AFR6 REPLACE AIR FILTER WITH NEXT OIL CHANGE. 335i/335is/335xi 07/13 QTY PART NUMBER PART DESCRIPTION PART PRICE EXT PRICE 1 BM13-71-7-556-961 AIR FILTER ELEMENT 39.93 39.93 LABOR $: 53.75 PARTS $: 39.93 GOG $: 0.00 MISC. $: 0.00 TAX $: 3.29 ------------------------ SUBTOTAL $: 96.97 -------------------------------------------------------------------------------- TOTAL LABOR $: 4723.35 TOTAL PARTS $: 4790.42 TOTAL GOG $: 0.00 TOTAL MISC. $: 9.00 TOTAL TAX $: 395.21 -------------------------------- ESTIMATE TOTAL $: 9917.98 |
03-20-2019, 02:48 AM | #2 |
Rep 11,722
Some of these items can be DIY; but, it entails leaving your car out of commission for a while.
Just to give you an example and this is on my 1998 E36 M3, I redid the following: Water Pump, thermostat and aluminum housing, all associated hoses, serpentine belts, Vanos hose, Aluminum radiator, expansion tank, fan clutch, engine mounts, both left and right front control arms with upgraded polyurethane joint bushings, both left and right front wheel bearing, both left and right front and rear brake rotors, front and rear ABS sensor, front and rear brake sensors, front and rear Struts and shocks(coilover), alternator, battery, negative cable, ground cable, left and right RTABs: around $4k. I did most of the labor myself. |
03-20-2019, 05:39 AM | #3 |
Rep 7
Wow he upsold the hell out of you. Have you noticed all of these issues?
TheMidnightNarwhal2657.00 |
03-20-2019, 05:51 AM | #4 |
Drift Instructor @ BMW Club UAE
310
Rep 433
Drives: BMW F10 M5
Don't get me wrong, but ummmm
How much is a 2007 335 so start with? Isn't the quotation costing almost the same price of the actual car?
F10 M5 - AlpineWhite/SakhirOrange[DCT](Current)
F16 X6 - SparklingStorm/CognacBlack (Current) Follow me on Instagram (Click) |
03-20-2019, 06:57 AM | #6 |
Rep 1,101
Assuming you need all of the work that they identified, you're almost guaranteed to pay less at an independent mechanic. First step is to take the car to another mechanic and have them verify that all the work the dealership identified needs to be performed.
Assuming you need all the work, you can save a lot of money by purchasing these parts online yourself. You can get OEM parts without the dealer markup this way or use reputable aftermarket replacements for a fraction of the cost. The nice thing is that you already have all the part numbers listed to do your research. Also, as cbisson pointed out, it does look like they have the brake service listed twice. Not sure if thats a mistake or intentional but its a bit suspicious. |
03-20-2019, 07:01 AM | #7 |
Rep 1,322
90% of that is easy DIY shit. $70 in labor to replace the microfilter? Its like 6 screws and is sitting on top of the engine. Its a 5 minute job.
Brakes are stupid easy (and as noted they have a quote for all 4 AND the front and rear). You can get a brake bleeder kit for under $100 and ATE TYP200 for $20. Hell, get two and bleed the hell out of it. If you can get the wheel off you can bleed the brakes. Air filter is another couple of bolts, stupid easy job. The suspension is the real rape there. For starters, if they are putting new tires on your car they should be throwing in the alignment. Second, their labor is INSANE. $350 to replace a thrust rod bushing. And its $180 in parts, the whole arm is that and its 30 minutes with a lift. I did my ENTIRE suspension with OEM manufactured parts (all arms, struts, springs, bearings, CA links, etc) for less than what they want for the front struts. Honestly, Id never talk to this guy again and if he called me Id tell him to go F himself with that. Then Id go to pelican or FCP and start to buy the parts for the jobs. Feel free to tackle them as you can, piecemeal. Other than the brakes and suspension. Do the thrust arm (whole, don't dick with trying to press out the bearing, for the cost you get a new bearing and joint) with the suspension, do the brakes as a whole job. Do the spark plugs and OFHG together since youre up there. The filters can be done whenever. Honestly the only thing on this list that seems legit hard is that sealing sleeve. But based on this guys quote on everything else Im going out on a limb and say his is way too high anyway so find a good independent and get a quote from them. Honestly, even if these prices are fair, if Global Imports BMW/Baron BMW is any indication, youre better off going to an independent anyway. I have been really, really, really disappointing with the quality of service performed by dealers. Every single time I have taken my car to Global Imports they have fucked something up, something obvious that even having someone take a second look at would have been caught. I think anymore they hire morons who are only capable of doing recalls with specific instructions (and even then they screw shit up). |
03-20-2019, 07:08 AM | #8 | |
Rep 1,101
03-20-2019, 08:04 AM | #9 | |
Rep 3,539
Volasko705.00 |
03-20-2019, 09:12 AM | #11 |
Rep 18,733
Okay, step 1. The car has a brake pad monitoring system that tells you when the pads are spent and need replacement. There is a red icon that comes on and stays on until the pads are replaced and the monitoring system is reset. So is there a red "Brake" light on in the section of the gauge cluster between the tachometer and speedometer? At 2MM front and 1MM rear, the light should have been on for several months by now and the CBS system should be notifying you that brake service is due. If there is no light on, then the previous owner either tied off the pad wear sensors, or some how completely FUBAR'd the brake pad wear system. The only other explanation is the cars software was completely reflashed recently.
But as others have stated, just find a reputable independent BMW repair shop, which will charge you less than the dealer to replace the brakes. They quoted the brake job twice. The gave you a separate price for the fronts, and a separate price for the rears, the they quoted all 4 brakes as a single $1,500 job. As far as the struts and shocks, take a flashlight and look at them. If they are leaking, you will find evidence as a wet, oily, grimmey, spot on the strut tubes below the bottom spring perch (look above the top of the tire). The rest shocks if leaking will be wet below the plastic tube that covers the shock piston. Again look above the top of the tire. And again, the BMW Indy should replace those components far less expensively than the dealership. Who has been caring for this car anyway? Someone has been ignoring the CBS notifications. Last edited by Efthreeoh; 03-20-2019 at 09:22 AM.. |
e90yyc2425.00 |
03-20-2019, 09:25 AM | #13 | |
Rep 6,968
Drives: 2007 Black/Black 335i e90
03-20-2019, 09:47 AM | #14 | |
Rep 1,322
Cars arent financial instruments. They have an intrinsic value, fixing things and making the car reliable means you have, get this, a car that works. |
Wolf 3352340.50 |
03-20-2019, 10:00 AM | #15 |
Rep 1,485
looks like the guy charged you for front brakes, then rear brakes and then separate charge for all 4 brakes. I would find a more honest service advisor.
if you told him you have extended warranty, he might have overcharged on everything figuring you won't care. |
03-20-2019, 10:48 AM | #17 |
Rep 912
I think that's just a mistake....stands out like a sore thumb..
03-20-2019, 11:16 AM | #20 |
Rep 13,103
Lets see I did my spark plugs this weekend and changed the
cabin filter. Spark plug cost 11 dollar's each I got the good ones NGK iridiums. took 3 hours of my time and couple of scrapes. I think the double platinum's can be had for around 8. Cabin air filter 25 bucks or something like that. engine air 25 bucks. I would attempt to do my own OFG I think the gasket is 10 bucks but you might need a ratcheting torx . Also did the oil bought two 5 quart liquid moly bottles for 40 each leaves enough so next time I only have to buy one . Mann oil filter 8 dollars . All from FCP Euro. |
03-20-2019, 11:33 AM | #21 | |
Rep 870
Drives: 2009 335i E90
OP, please do some research on DIY stuff and save yourself thousands of ducats on future maintenance.
2008 E61 535xi Sport Wagon / 100k Miles / Deep Sea Blue Metallic / Natural Brown Interior / MHD Stage 1 91 CA-Octane Tune.
SOLD - 2009 E90 335i M-Sport Sedan / 143k Miles / Alpine White Exterior / Chestnut Brown Interior / Mishimoto FMIC / xHP Stage 2. |
03-20-2019, 11:36 AM | #22 |
Rep 13,103
Or find a Indy you can trust.
There is some stuff that is really hard to do by yourself or without a lift. The biggest thing I see on you list like that would be the Mechatronic sleeve. But that is a guess on my part. |
