01-26-2020, 09:00 PM | #1 |
Rep 76
SAT 2TB activated
Hi everyone, I just wanted to share my experience and impressions upgrading to 2TB (sport automatic) with bimmercode. I have a 11 535i xdrive base with (steptronic) 205 transmission.
This was the best thing I have done to the car, vast improvement in shifting quality and more intuitive even in just D, even better in S and Manual mode. Before this the car was ok but did feel lazy and too smooth(hard to explain). But for anyone with the 205 my suggestion is go get 2TB coded ASAP! You wont regret it. |
01-26-2020, 09:12 PM | #2 | |
Rep 1,873
Yet, I read stuff like the above. I have a theory. I do not have a DEC switch (econo/comfort/sport switch). Do you? I have a feeling that anyone without this switch gets no benefit from any coding. XHP transmission tune, however, made a world of difference. |
01-26-2020, 09:25 PM | #3 | |
Rep 5,379
01-26-2020, 09:46 PM | #4 | ||
Rep 76
01-26-2020, 09:49 PM | #5 | ||
Rep 76
ezaircon4jc4528.00 |
01-26-2020, 09:51 PM | #6 |
Rep 76
This was just from the demo mode from bimmercode as Im not connected to the car now.
01-26-2020, 10:47 PM | #7 |
Rep 5,379
01-26-2020, 10:54 PM | #8 |
Rep 2,591
Bimmercode doesn't do VO coding, it just does an en masse FDL coding for all the relevant parameters.
2015 BMW 535xi
01-26-2020, 11:33 PM | #9 | |
Rep 76
01-26-2020, 11:39 PM | #10 |
Rep 5,379
WinstonE92xi64.50 |
01-27-2020, 04:29 PM | #11 |
Rep 1,873
Well, I'm stumped. My 2011 535i X-Drive had no difference of any kind when VO coding 2TB from 205. I did it as a shortcut to retrofit paddles instead of FDL coding lesser known entities in SZL.
01-27-2020, 10:32 PM | #12 | |
Rep 76
01-28-2020, 05:41 AM | #13 | |
Rep 1,873
I've made several rounds of posts in coding forums years ago, never a conclusion why some people report significant change and for others (including me) no difference other than paddles worked and the cluster showed S1,S2,S3 when in sport mode (all signs that it's coded properly). |
01-28-2020, 09:18 AM | #14 |
Rep 2,591
Just to confirm, which ECU did you VO code? IIRC you need to VO code quite a few for 2TB.
2015 BMW 535xi
01-28-2020, 09:56 AM | #15 |
Rep 5,379
When I did it in ESys all I had to do was replace 205 with 2TB in the VO. I swapped out my old wheel with one with paddles and they worked immediately. For them to work properly with the SAT I had to code a couple of modules; though I don't remember which (check the coding forums).
01-28-2020, 11:01 AM | #16 | |
Rep 2,591
2015 BMW 535xi
01-28-2020, 11:27 AM | #17 |
Rep 1,873
01-28-2020, 12:46 PM | #18 |
Rep 2,591
That sounds about right, just making sure you coded the right ones. Would have been a bit awkward if you didn't feel the difference because you forgot one of the modules :P
2015 BMW 535xi
01-29-2020, 10:17 AM | #20 |
Rep 2,591
It's a lot more complicated but it's the proper way to retrofit 2TB. It also ensures that if your car gets ECU updates, they'll be specific to 2TB and not 205, which might matter.
2015 BMW 535xi
WinstonE92xi64.50 |
01-29-2020, 07:44 PM | #21 |
Rep 1,873
01-30-2020, 10:50 AM | #22 | |
Rep 76
