2010 2011 BMW 5 Series Forum F10 F10 pre lci adaptive headlight failure |
06-28-2024, 12:35 PM | #1 |
Rep 4
Hi everyone,
I bought myself F10 couple of months ago and it came with headlight vertical aim failure error. I pulled the codes with ISTA and they are: 800FC2 Initialisation fault in headlight driver module, right 800FC6 Internal fault in headlight driver module, right I have tried initialisation of headlights in ISTA but without any success. If I start the car normally It doesn't give any messages, only when turning on ignition (without starting the engine). Lights themselves work except the adjustment up and down, left and right. I don't know if it's related but passenger side turn indicator blinks occasionally for a brief moment when not turned on. How should I start with the troubleshooting procedure? I do have K+DCAN and ENET cables so I'm able to use ISTA end esys. I tried to look on forums for the same problem but mine seems bit different since the error message is not even showing while car is running. I appreciate any help, thanks! |
