2010 2011 BMW 5 Series Forum F10 535 xDrive Shuddering under acceleration |
12-16-2020, 04:14 PM | #1 |
Rep 2,091
Hey guys I recently purchased a 535 xDrive for cheap to fix up.
The car has what feels like a drive train vibration/shudder (whole car shakes) when putting the engine under load in high gears around 2-3k ish rpm (most noticeable when engine is up to temp). This happens most often in comfort mode since the RPM's are lower and it won't downshift as quick as sport. There are no codes. It has been to 3 different shops. Recent shop said they unplugged the transfer case and the issue was still there. They are thinking its the torque converter and trans. I have tested xDelete as well and the issue remains in RWD. Work done at other shops to try and fix the issue: - Replaced all coils and plugs - Replaced rear driveshaft giubo - Replaced rear differential bushings - Walnut blasting Anyone have any ideas? Could the ZF8 be the issue? Should I try a transmission fluid/filter service?
MGM F82 M4 DCT / MPerformance / Swift / CSF / IND / Turner / BimmerWorld
BSM F87 M2 6MT / Fabspeed / MPerformance / Turner / AutoID - SOLD JB-NB E92 M3 6MT / IND / RTD / Alpine / KW / ActiveAutowerke / 360Carbon - SOLD SS2-FR E90 M3 6MT / IND / AFE / ActiveAutowerke - SOLD AW-FR E90 M3 DCT / ACM / IND / AutoTecknic / K&N / H&R / Bilstein - SOLD Last edited by Drifter2090; 01-11-2021 at 08:39 AM.. |
12-18-2020, 10:11 AM | #2 |
Rep 2,091
Going to check the center support bearing.
BSM F87 M2 6MT / Fabspeed / MPerformance / Turner / AutoID - SOLD JB-NB E92 M3 6MT / IND / RTD / Alpine / KW / ActiveAutowerke / 360Carbon - SOLD SS2-FR E90 M3 6MT / IND / AFE / ActiveAutowerke - SOLD AW-FR E90 M3 DCT / ACM / IND / AutoTecknic / K&N / H&R / Bilstein - SOLD |
12-18-2020, 10:47 AM | #3 |
Rep 2,587
Check center support bearing and guibo
2015 BMW 535xi
Drifter2090908.00 |
12-19-2020, 08:36 PM | #4 |
Rep 2,091
Checked the center bearing today, looks like it spins too freely and has a tiny bit of play. Going to replace that. I already replaced the rear giubo. The front metal one doesn't usually fail right?
12-19-2020, 09:05 PM | #5 |
Rep 2,587
Haven't heard about problems with the front one.
2015 BMW 535xi
01-11-2021, 08:40 AM | #6 |
Rep 2,091
Changed the center support. Same issue.
Could trans fluid/filter service help?
01-11-2021, 09:00 AM | #7 |
Rep 2,587
It could. How many miles?
2015 BMW 535xi
01-11-2021, 09:40 AM | #8 |
Rep 38
I had this same issue, it took a lot of effort to track it down.
535i 6MT. at 50k miles!, turned out to be a faulty Diff...after replacing guibo, fluids, and some other bushes. i replaced with a very lightly used (20k mi @ $150) diff from a totaled 528i (diff has same part number). Significantly cheaper than from BMW. Now at 90k, and no issues. EDIT: This was a GIF, i do not know how to post a gif or video. It shows the significantly play in the diff Last edited by strongislemax; 01-11-2021 at 10:06 AM.. |
01-15-2021, 01:12 PM | #9 |
Rep 2,091
01-15-2021, 01:15 PM | #10 | |
Rep 2,091
This might also explain why xDelete doesn't change the symptoms. Can you explain the issue you were having? also if possible can you email me the GIF? Thanks!
01-15-2021, 02:25 PM | #11 |
Rep 38
My 535 is a 2014.
I bought a differential from a 2015 528i on ebay. I was experiencing a shudder under acceleration. It was the type that you could feel through the floor boards and seat...not as much through the steering wheel (like wheel balance issues). The faster I drove, the worse the vibration got. You can see in the pic, some scoring. PM me your email, and ill send you a vid. |
Drifter2090908.00 |
01-18-2021, 01:35 PM | #12 | |
Rep 2,091
I took down my driveshaft yesterday and checked the yoke splines on the differential and transfer case to be sure. All the teeth were perfect. So back to square one lol
01-18-2021, 05:00 PM | #13 | |
Rep 110
OnlyGerman362.00 |
01-19-2021, 08:31 AM | #14 |
Rep 210
Yes, you should try replacing the trans fluid and pan/filter. If it's never been replaced, that could cause all sorts of issues.
Drifter2090908.00 |
01-20-2021, 10:50 AM | #15 |
Rep 2,091
I already changed all of them
OnlyGerman362.00 |
01-20-2021, 10:51 AM | #16 |
Rep 2,091
Will give it a shot.
OnlyGerman362.00 |
11-14-2021, 07:57 AM | #18 |
Rep 2,091
Nope, got rid of the car
02-09-2022, 09:48 AM | #19 | |
Rep 3
02-09-2022, 11:51 AM | #20 |
Rep 1,259
Mine doing the same for quite some time. Already did rear diff fluid and trans service before this issue arose. Have warranty so may need to try for center support or maybe entire rear diff.
02-09-2022, 12:57 PM | #21 |
Rep 1,356
There is a possibility that the clutch in the transfer case is slipping as well. If you unplug the harness to the transfer case actuator and it drives smooth, your clutch in the transfer case is gone.
02-25-2022, 04:39 PM | #22 |
aa240sx
15
Rep 21
Did you end up doing a fluid service? At 99K, if it was never done, not so sure I would go that route. Best to just leave a transmission alone if it's an automatic at that mileage.
2012 F10 535i Msport - Sophisto Metallic
2003 E46 M3 6speed (converted) - Alpine White |
