2010 2011 BMW 5 Series Forum F10 2015 535i - wifi / screen mirroring? |
11-30-2021, 10:37 AM | #1 |
Rep 36
I am trying to see if i can wifi-direct / miracast youtube in my 2015 535i... so I have coded
3000ENT_MC_WLAN_STREAM_DMP_COVERARTset to: aktiv 3000ENT_MC_WLAN_STREAM_DMP_VIDEOset to: aktiv 3003WLAN_STATUSset to: aktiv 3003WLAN_MODUSset to: ap 3003WLAN_SIGNAL_STRENGTHset to: outdoor 3003WLAN_CHANNELset to: channel_1 so I can see the wifi option in connection now but I cannot check the box to activate wifi could anyone help?? am I missing something in the settings? or 2015 535i simply cannot do screen mirroring? there is not a wifi_lan_direct nor a ent_miracast in my coding list Last edited by teknodogg; 11-30-2021 at 01:55 PM.. |
12-08-2021, 01:51 PM | #3 |
Rep 19
I don't think 2015 has wifi. Start with checking if there is WiFi antenna plug at the back of the headunit.
OnlyGerman362.00 |
12-08-2021, 04:33 PM | #4 |
Rep 36
Anyone knows for sure? don't want to rip off all the trim and head unit to get to the back just to check but it make sense bc no wifi unit so option can not be selected, but anyone know if i added a wifi module will I be able to do miracast??
12-08-2021, 10:43 PM | #6 |
Rep 36
would this work?
https://www.ebay.com/itm/16503556644...3ABFBM8pTs17Nf if not do anyone know the part number?? where is the wifi supposed to go? even if the wifi module is there would I be able to miracast? Last edited by teknodogg; 12-09-2021 at 07:57 AM.. |
12-09-2021, 10:04 PM | #7 |
Rep 19
Notice the headunit you post has wifi icon on top but I can not clearly tell if it has wifi antenna connector on the back. IIRC is it red-ish color so maybe it's the one right under the quadlock connector.
But also notice it does not have Sirius radio version so it is not the US version headunit. And it's not a quick DIY PNP job because you need to flash the correct VIN to the headunit and load FSC codes for any of the functions to work. You can't just slap in a used unit. However there are plenty of sellers that will sell you a properly coded unit for a good price. |
12-09-2021, 11:08 PM | #8 |
Rep 36
that is not my actual unit...I am trying see if adding a wifi module will let me miracast
this wifi antenna is what i found not sure if it will work or worth the trouble to add https://www.ebay.com/itm/16503556644...3ABFBM8pTs17Nf |
12-29-2021, 04:03 PM | #9 |
Rep 19
I have just removed the NBT ID4 headunit from my 2015 528i USA and there is indeed a wifi antenna connection. Although I am not sure what you can do with it.
Harman Automotive Model NBT HU FCC ID T8GB067 Date code: 21/15 BMW P/N 9387568 |
