2010 2011 BMW 5 Series Forum F10 N55 Valvetronic is angry |
07-27-2019, 04:39 PM | #1 |
Rep 216
2013 535i with Valvetronic issues. Has anyone else dealt with this? I’m going to get the valve cover off and see what is going on. I’m hoping I can just replace the servomoter and the eccentric shaft isn’t damaged.
Codes: 133B04 - Valvetronic system: no adjustment possible 133E10 - Valvetronic system: deactivated, adjustment fault too frequent 124k miles |
04-03-2020, 09:40 PM | #2 |
Rep 216
Well, I finally broke down and swapped the valvetronic solenoid yesterday and it cleared all my faults. It wasn't that hard with the proper fuel injector removal tool. Glad she's all happy once again.
OnlyGerman362.00 |
04-04-2020, 11:05 AM | #4 |
Rep 216
The Valvetronic Eccentric Shaft Actuator was $198.64 and the fuel injector removal tool was $35 on Amazon. The oil squirter doesn't have a revised part number so I cleaned mine and reused. 3.5 hour job in my garage. Local Euro shop quoted $3700, but they'd be replacing the eccentric shaft, the wiring harness long with a bunch of labor as well. Mine was moving smoothly with no damaged teeth so left it alone.
04-04-2020, 11:33 AM | #5 |
Rep 1,442
Drives: 2011 535i 6MT
Wow nice savings! These cars are well worth the effort if you can work on them yourself!
04-04-2020, 09:27 PM | #7 |
Rep 216
That's what I read. You do seem to read about cases of chipped and broken gear teetH on the eccentric shaft. But the motor seems to be a pretty good fix for most.
04-06-2020, 06:21 PM | #8 |
Rep 4,632
Good update and good work! will def help future owners and members.
Current: E63S AMG 4matic RENNtech || M5 Evolve..Eventuri || F10 LCI 535i MHD
12-11-2021, 06:33 PM | #9 | |
Rep 1,442
12-12-2021, 10:05 AM | #11 |
Rep 1,356
It depends on the position of the eccentric shaft. Certain position will not allow the engine to start. I forgot if it's all the way up or down. One of those position will allow it to start.
OnlyGerman362.00 |
06-21-2022, 05:40 PM | #12 |
F10 535i EFR 9280. F90 M5 Individual on order
Rep 5
Hey man, just curious, did you have to do a relearn procedure for the new valvetronic motor?
