05-20-2020, 08:59 PM | #155 |
Rep 14,522
yup KW's and yes they lined up perfect!!! just reused my KW bolts. interesting to see you're having issues when we have the same brand coilovers
ey2001310.00 |
05-20-2020, 09:47 PM | #156 | |
Rep 716
05-20-2020, 11:05 PM | #158 |
Rep 716
05-21-2020, 10:51 AM | #162 |
Rep 14,522
No, I immediately noticed the difference. Handling has much improved. I've had strut bars all the back in my Import days so I knew that when someone made a bar for the BMW I was definitely gonna get one. Not gonna upgrade my sways cause I don't want the car to be too stiff. For me I feel my car is dialed in perfect for my kind of driving
05-25-2020, 03:40 PM | #164 |
Rep 82
Hey guys, just installed the strut bar but I'm noticing a little bit of play. Can you guys take a look on the YouTube video I uploaded. I'm not sure what I could do, it's pretty darn tight already. |
05-25-2020, 04:36 PM | #165 |
Rep 716
05-25-2020, 07:39 PM | #166 | |
Rep 82
Any ideas about my video though? |
05-25-2020, 07:42 PM | #167 | ||
Rep 716
05-25-2020, 11:42 PM | #168 |
Rep 2,591
The bolts holding the actual bar to the base is fully tight correct? Post a picture of that linkage so I can verify the bolt setup is correct.
2015 BMW 535xi
05-26-2020, 12:24 AM | #169 |
Rep 14,522
Seems like you don't have the bolt that's connecting the strut bar to the brace tightened? Video was kinda quick to see what's moving at the base
05-26-2020, 02:13 PM | #172 |
Rep 82
Here are pictures of the install.
I used a hex tool to hold one side (to prevent from spinning) and a wrench to tighten and they are tight. Then I used a wrench to tighten the bar across Did you guys do something different? |
05-26-2020, 03:42 PM | #173 |
Rep 2,591
In the last picture, you can see a big gap between the bar and the black base. Tighten that down more.
2015 BMW 535xi
05-26-2020, 06:40 PM | #174 | ||
Rep 82
I tried. Nothing happens. The bolt that went through the tower brace and bar won't get any tighter. Are you guys using the same method to tighten? By using a hex tool on the hexa head then wrench on other side? |
05-26-2020, 08:50 PM | #175 |
Rep 2,591
I didn't use a wrench. I used a socket that fit snuggly and a hex. Both were on breaker bars, you're basically trying to bend the bracket initially. Then, back it off a tad and then torque down to 24nm.
2015 BMW 535xi
05-26-2020, 09:59 PM | #176 | ||
Rep 82
Woohoo! Got it to work and now it's snug thanks for the recommendation. |
