2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum Headlights right side BMW F10
      04-19-2022, 11:30 AM   #1
sylky
Italy
Drives: BMW F10
I have a problem with the condenser of the headlights. Only on the right side. How can I solve it?
      04-19-2022, 12:33 PM   #2
lukavergille
lukavergille's Avatar
Georgia
206
Drives: BMW 535i F10
2013 BMW 535i  [9.50]
Just my 2 cents..
Open the the hood and right above the headlight there is a black triangle-ish plastic, you can open it and then you will see a headlight cap. Turn the cap to the left to remove it and leave it open for a few minutes.
My driver's side headlight started to condensate after snow - water drops would appear inside the headlight after every wash. Then i opened that headlight cap and left it for like 20-30min and it solved the condensation for me.
You probably would want to protect the headlight from dust - i used a cloth to cover it and give a place for air to come out from the side
      04-19-2022, 05:43 PM   #3
jarsdad1
Drives: 2011 535i, 2015 X1 3.5
I'm not sure about LCI models, but early models also have a cap accessible through the wheel well. Rig some string on a couple of desiccant packs and put them in both holes. That should help with drying. A hair dryer on low setting will work. too.
      04-20-2022, 05:47 PM   #4
TZ
Drives: 2011 535i xDrive, 2014 435i CO
Originally Posted by lukavergille View Post
Just my 2 cents..
I found this works for me too! In stead, I go a little further, drilling a hole on the cap and have a presentment opening. So far, no more condensation.
2014 435i RWD Convertible
Service Manual: www.newtis.info
Part: http://www.realoem.com
      06-02-2022, 04:06 PM   #5
PeterPersson
Drives: BMW F11 520d
Thumbs up
I've thought about to do the same. May I ask how big holes you drilled?
      06-03-2022, 07:04 AM   #6
Aussie_550i
Australia
12
Drives: 2011 550i, 2017 430i
I've found that removing both caps, cleaning the existing rubber seal and then rubbing the smallest amount of vaseline and then closing them again will stop condensation.
I wouldn't be drilling a hole.
Just my 2 cents...
      06-03-2022, 08:14 PM   #7
TZ
I drilled a 3/8" hole on each cap and leave them open for 6 months now. So fare so good, no more condensation.
      06-03-2022, 08:19 PM   #8
OnlyGerman
OnlyGerman's Avatar
Drives: F15, F13, F10, E60
Failing seal. Can be repaired
      06-19-2022, 03:28 PM   #9
PeterPersson
Thanks TZ! I drilled 15 mm holes on each top-cap. Condensation gone after 2 days and haven't come back since. Have had heavy rain for a couple of days now and everything is still dry.
Had to replace one headlight driver module due to corrosion a couple of months ago, and was afraid it would happen again..Now, finally, I think my issues are gone.
      06-19-2022, 10:32 PM   #10
OnlyGerman
OnlyGerman's Avatar
Good to hear. Just keep an eye on it. Most times it is failing seal, or something with the caps (failing or forgot to put back).
The moisture has to come in from somewhere to mess with those modules, so it's just figuring out where.
