2010 2011 BMW 5 Series Forum F10 rotors and pads share your experience... |
03-04-2019, 07:14 AM | #45 | |
Rep 431
03-04-2019, 07:45 PM | #46 |
Rep 175
X5M OEM front brake system
Rear are aftermarket from oreilly and ceramic pads. Not as bad on the dust But boyyyyy do they stop. Initial bite is ridiculous, very touchy. Wakes me up in the morning of the first drive of the day lol. 2011 550i 6mt |
03-05-2019, 04:20 PM | #47 |
Rep 4
I just replaced both front and rear rotors and pads plus sensors. Went with ATE 2 piece rotors and Brembo pads, replaced retaining springs too, using pagid parts. Rear rotors had worn from 20mm to 18.25mm and fronts from 24mm to 21.20mm (below minimum spec). Car had done 78300 miles.
03-07-2019, 08:59 PM | #48 |
Rep 1,158
Retrofit M5/M6 6piston brembo to my 550iM but it's not going well, rotors is warped after less than 10K wonder if TRONIK bracket kit is legit or if he did the right measuring for the kit!
BMW f10 550i Msport
03-24-2021, 09:57 AM | #50 |
Rep 2,587
I'm running them. I like them. Anything specific you want to know?
2015 BMW 535xi
Bootmod3 Stage 2 | ER charge pipe | ER Catted DP | Remus Exhaust | Gplus FMIC | KW V3 | Turner Monoball thrust arm bushings | Wallet regrets ISTA VM Setup/Tutorial |
03-24-2021, 03:35 PM | #51 |
Rep 14,522
i know it's an older thread but figure i'd share my setup
custom rotors from CQuence brakes! had this design with drilled/slotted design
~F90Conversion~21"3Piece Forged AvantGardeWheels~KWV1Coilovers~CQUENCE slotted/drilled rotors~GoodridgeStainlesslines~MeisterschaftQuadEx haust~Akrapovic 4"tips~VRSF DP~VRSF CP~TurboSmart BOV~K&N filter~CarbonFiberExteriorComponents~GladenAlphaCo mponents~MatchUp7BMW~Punch P300-12T~ Follow me on Instagram: lsturbointeg |
04-01-2021, 01:17 PM | #52 | |
Rep 30
How is the feel/bite relative to the original/textar/akebono pads(whatever you had before)? FCP seems to be excited about this new line of TRW pads. They say the cold bite is better than Akebono, yet still low dust. I was debating between original BMW or Textar epad(which could be the same thing). But TRW seems to be half price! |
04-01-2021, 04:20 PM | #53 | |
Rep 2,587
2015 BMW 535xi
ashmailusa4.50 |
04-06-2021, 11:05 PM | #54 |
Rep 30
04-07-2021, 12:02 AM | #55 |
Rep 2,587
OEM
2015 BMW 535xi
08-07-2021, 04:43 PM | #56 |
Rep 73
08-07-2021, 10:12 PM | #57 |
Rep 2,587
No issues at all. They're maybe a tad sqeaky when cold but that's not a problem for me. I did not use loctite as I replaced the bolts, but you can use it if you thread chase or clean off the old loctite.
2015 BMW 535xi
08-08-2021, 08:00 AM | #58 |
Petrolhead
438
Rep 804
Drives: 24 X3 M40i/14 550i/08 Z4 3.0si
Brembo rotors are expensive but really good. They're OE without BMW logo after all. I'm very happy with them.
Brembo NAO Ceramic pads are a dud. Good stopping power and no squealing, but produce insane amount of brake dust. INSANE! Stay away.I also don't like that they have a red back plate, especially with painted calipers. I'm now switching over to Power Stop Z23 pads for the fronts and back. Seem very popular with the M5 crowd and have good reviews. I'll report back after installation and break-in period.
2024 X3 M40i 2014 550i 2008 Z4 3.0si 6MT 2011 Z4 35si (sold) |
