2010 2011 BMW 5 Series Forum F10 Need help with windshield washer fluid leak 535i |
09-11-2024, 06:33 AM | #1 |
Rep 27
Have f10 535i with fluid leak behind passenger front tire. replaced o ring where hose meets the tank (using 7/8 ID oring) but it's still leaking. i wish i had filled and observed prior to putting it back together but was in a time crunch. anyway either my oring didn't work or it's something else. i read somewhere the pumps also leak - is that true on the f10? if so, can the tank/pump be removed by sliding it out versus having to take the fender off? taking the fender off seems overwhelming. trying to decide to go ahead and order a pump but unsure about the accessibility. thanks for any help.
09-11-2024, 08:11 PM | #2 |
Rep 517
Drives: 2016 F10 BMW 535i M Sport
Go to RealOEM.com put your last 7 of the Vin, this is for an example for your reference. Your Diagram should be accurate to what you have.
09-11-2024, 08:13 PM | #3 |
Rep 517
If you have to, take your time removing what is necessary to get to where you need to be, be patient.
09-12-2024, 01:27 AM | #4 |
Rep 3,607
Drives: 2006 BMW 330i MT
Garage List 2006 BMW 330i [8.25]
2009 BMW 328i Touri ... [8.00] 2013 BMW X5 35i [7.80] 2011 BMW 528i [8.70] 2006 Mazda3 [5.50] |
Looking at that image, it looks to be VERY similar to an E90 set up. If that's the case, then yes, the pumps definitely leak. That's usually the source of the leak in an E90, not the O-ring on the fill hose. I don't know how to access it on an F10, but on the E90 you don't need to pull the fender (but it helps and is not that hard).
ChiltiCoatl891935.50 |
09-12-2024, 08:22 PM | #5 |
Rep 150
According to this link and post by CTrent06 there is no need to fully remove the fender.
Keep in mind that reservoir for cars with headlight cleaning system is different than those without cleaning system. https://www.bimmerfest.com/threads/w...ervoir.989490/ |
StradaRedlands5992.00 |
