2010 2011 BMW 5 Series Forum F10 2014 LCi 550i with 343m wheels and with 5 or 3 mm spacers |
09-08-2023, 11:52 AM | #1 |
Rep 182
Hi
i have 343m wheels but it doesn't looks like its fit perfectly in my LCI 2014 550i am getting the calipers scratched for front wheels, but with 10mm spacers the wheel poke out badly , i want a flush fitment without scrapping the calipers, have anyone done this with 5mm spacers ,cause after the spacers very small space is left in hub center bore not feeling much confident weather the wheel will sit or not at high speeds. let me know if some one achieved this.. |
09-08-2023, 12:17 PM | #2 |
Rep 76
Are you 100% positive that the wheel is rubbing on the caliper? I have the same car with the same wheels no rubbing at all. It is close but it does not touch my calipers are painted red so I’m positive it doesn’t touch. Your caliper has the indentation in the middle opposed to the earlier years which doesn’t. Wheels should fit just fine if they are indeed OEM.
09-08-2023, 04:28 PM | #3 | |
Rep 182
Smytty do u have the same space as mine as per pic ? are u using any spacers ? and are u feeling any vibration while going on 90mph? |
09-09-2023, 07:34 PM | #4 |
Rep 76
If you’re referring to the space between the caliper and wheel yes I do; only a couple mm but the wheel does fit no rubbing. I do not get any vibration at high speeds. Fortunately wheels were mint from the person I bought them from on this forum. I would make sure they are road forced balanced and check any suspension components. If you like I can send a picture of the space I have tomorrow. If all things are the same you shouldn’t have a problem with the wheels rubbing. I am not running any spacers.
09-09-2023, 10:20 PM | #5 | |
Rep 182
09-11-2023, 11:22 AM | #6 | |
Rep 15
09-11-2023, 10:05 PM | #7 | |
Rep 182
and i have 464m wheels currently and it sit perfect. |
09-12-2023, 10:51 AM | #8 | |
Rep 182
I tried to position this in center and put the bolt on but no matter I try it’s not in center and the gaps u can see from below pic |
09-12-2023, 11:32 AM | #9 |
Rep 246
Drives: BMW 550i
Are whose OEM or reps? Asking because Mating surface looks different. I have m6 version of same wheels and getting 7mm +/- gap with no spacers
09-12-2023, 01:24 PM | #10 | |
Rep 76
Here are some pics on how mine look. Just enough space so there’s no interference. Wheels fit perfectly on hub no gaps. If you take your center cap out can you see what is or may not be touching? If the wheels aren’t sitting on the hub lip I am afraid those may be reps. |
09-12-2023, 02:13 PM | #11 | |
Rep 182
Thanks for responding Smytty NikMN can I request to show me the mating place of ur wheel or the center hub in wheel . Is ur center hub in wheel same as mine? If u see the first pic it’s up and down it’s not straight flat . I check the wheel it’s OEM it have part number , bmw seal , and made in Germany . |
09-12-2023, 03:07 PM | #12 |
Rep 246
Drives: BMW 550i
This is picture of a rep. Mating surface (silver area) looks cast vs OEM is machined. Also OEM part number are stemped where you see smaller holes. Last test is the cost. Used OEM are $400 and up per wheel. New around $1500 each. I can snap picture later
09-12-2023, 03:42 PM | #13 | |
Rep 182
09-12-2023, 03:53 PM | #14 |
Rep 1,174
i have the oem 343m wheels from the m5, on my 2014 550i.
running 285 / 30 / 20 in back and 255 35 20 up front. with 3MM spacers up front to clear the brakes...no shaking/vibrating etc... lowered on ACS Springs |
09-12-2023, 05:39 PM | #15 |
Rep 76
09-12-2023, 06:20 PM | #17 |
Rep 246
Drives: BMW 550i
Hope this helps.
09-12-2023, 06:28 PM | #18 |
Rep 182
NikMN thanks his helps . Do u know the hub mm for 343 m wheels and f10 center hub ? I believe 343m have 72.6mm not sure abt the f10 wheel center hub
09-17-2023, 09:12 PM | #19 | |
Rep 182
09-22-2023, 06:41 PM | #20 |
Rep 246
Drives: BMW 550i
You need to find out if wheels are stock or replicas.
09-24-2023, 11:52 AM | #21 |
Rep 2,637
If you want to run 3mm spacers, you can do it with no real issues. I did it for a while. Anything beyond that and under 10mm you'll need hub extenders. I have a set from VAC.
2015 BMW 535xi
09-24-2023, 02:29 PM | #22 |
Rep 182
after 3mm spacers, very small space left for wheel to sit in hub.. feeling not very confident abt it ..
