2010 2011 BMW 5 Series Forum F10 351m square setup for tires |
05-11-2022, 09:21 PM | #1 |
Rep 63
Hey guys I just got a set of 351m wheels and they are a square setup with the 19x8.5 setup so what tires are the best? Right now I'm thinking Goodyear eagle LS2 Run Flats all season. WHAT SIZES CAN I PUT ON THESE RIMS BESIDES 245/40/19 & 255/40/19??? Or are those the only 2 sizes I can run?
I am looking for run flats as well as all season and I know the backlash but I have a lot of pot holes and am moving back to Michigan and then Knoxville TN in the fall so say what you want but I am getting Run flats and all seasons. Appreciate any help and input |
05-12-2022, 09:17 AM | #2 |
Rep 697
Drives: 2013 535xi
Two points:
1. You can go 245/45/19 on all four with your 351m wheels, no problem at all. I did the equivalent setup with my winter tires and they thickened the sidewalls with associated improvement in ride. 2. Unless the Goodyear LS2 Runflats have improved (which is quite possible) I would not recommend them based on my experience. These came with my new F10 back in 2012, and they are quite fragile to blistering upon moderate impact with potholes. They also don't have the best handling and the ride is somewhat harsh (my subjective opinion, of course). Many have provided good feedback in this forum for the Michelin all season runflat tires.
2010 Z4 35i, Crimson Red, beige interior, 6sp manual, Adapative Suspension 2000 528i, Cosmo Black, beige interior, Sport package (retired) |
05-12-2022, 09:58 AM | #3 | |
Rep 63
05-12-2022, 01:51 PM | #4 | |
Rep 697
Drives: 2013 535xi
Second point - yes, the larger diameter tire will indeed cause your speedometer to read lower than it was for the same actual speed. Given that most modern BMWs appear to already read higher than actual (average seems to be around 5%) you could very well make your speedometer more accurate by upsizing your tires. This was exactly my experience when I upsized my tires. So you are not guessing, I recommend you try different tire sizes on a wheel/tire calculator, like this one to get a feel with what goes on when you change tires sizes. If, however, you are just looking for advice on what tread width of tire you can go (besides just 245mm) then there are certainly others with more experience on that topic than me. I did successfully change my rear tires to 275/35/19 to match my front tires of 245/40/19, thereby creating a staggered setup with the rear wheels being wider than the front by 1".
05-12-2022, 03:03 PM | #5 | ||
Rep 63
05-12-2022, 05:12 PM | #6 |
Rep 697
Drives: 2013 535xi
In my humble opinion, a definite yes. You should be fine.
05-12-2022, 07:57 PM | #7 |
Rep 1,035
Did the same, and agreed 100%. Here's 245/45-19 on 19x9 on stock suspension.
05-19-2022, 11:33 AM | #8 | |
Rep 63
cdmulders326.50 |
