2010 2011 BMW 5 Series Forum F10 BMW M-Button Module for 550i 650i |
07-12-2020, 06:32 AM | #1 |
Rep 63
Hi people,
long time I was annoyed, that I have to use the "Driving Dynamics Control" switch somewhere in the car to get it into some sport mode and also have to pull gear selector for transmission sport mode. So for M-Cars there are steering wheel buttons to do that, called M1 and M2. So I thought there must be a way to fit them in non M-Cars. Just retrofitting the missing Buttons does not work, so i developed a module to provide the missing function. I build these modules for hobby, but if someone is interested just contact me. So now let's discuss what you think about it. What the module does: This module enables you to activate your preset driving mode with a press on a steering wheel button. To do so it uses the distance buttons from ACC which act as M1/M2. If you have none of these buttons, you can retrofit them or you can also use the cruise control wheel (faster/slower) as M1/M2. You can store the activated driving mode, by press and hold the desired button for about 4 seconds. After that you can activate/deactivate it by just a normal push. It does not only store Comfort, Sport, Sport+ etc., it also stores transmission mode (D or S). Requirements: -BMW 5 series 550i F07 F10 F11 -BMW 6 series 650i F06 F12 F13 -Production Date 2013+ -M sports steering wheel (-optional MFL Buttons for ACC 7849406, the ACC buttons will work as M1/M2) (-optional Chinese M1/M2 button, for fitting button symbol) Installation: -Installation is plug and play, you only have to plug it between gear selector and "Driving Dynamics Control" switch. No soldering, crimping, etc. required. -No coding necessary Optional: -You can open/close the exhaust flaps with button push on the steering wheel. The selected mode will be stored even until next car start. FAQ: -Does the module also fit for other BMW models? A: In theory it does, it should work for every 5 or 6 series build 2013+ and with 8HP transmission, but it's only tested for 50i models! -What happens if gear selector is changed or "Driving Dynamics Control" switch is pushed while M1/M2 mode is active? A: M1/M2 mode get's deactivated -What happens if the car is turned off while M1/M2 mode is active? A: M1/M2 mode get's deactivated -What happens if cruise control is active and wheel up/down is used as M1/M2 button? A: Cruise control buttons will work as usual, M1/M2 function is disabled while cruise control is enabled. -What happens if active cruise control (ACC) is activated and distance increase/reduce is used as M1/M2 button? A: Cruise control buttons will work as usual, M1/M2 function is disabled while cruise control is enabled. Demonstration: greets jeezz Last edited by jeezz; 07-22-2020 at 06:02 AM.. |
07-15-2020, 10:42 PM | #4 |
Rep 949
This sounds pretty awesome if you are able to provide the on demand Exhaust Flap open/close feature.
Does the gear selector switch also automatically move left to Sport mode if that is what you program it for? I'm willing to give it a shot on the N63 platform. Fwd me any info you have |
08-13-2020, 10:19 AM | #8 |
Rep 44
There was something wrong with my account. Finally got around to creating a new one. Can you please provide more info? Thanks
F12 650i M-Sport, F80 M3, G01 X3 M-Sport
08-23-2020, 09:37 PM | #9 |
Rep 738
I looked up the F10 M5 buttons which are 61317849407, will this work as well, my 550i doesn't have ACC. How much for your module ?
2011 550i
2013 M5 2014 M5 CP 2016 550i |
08-30-2020, 03:48 PM | #10 |
Rep 63
11-17-2021, 06:57 AM | #14 |
Rep 639
I'm also curious if this device is still available! Also would like to know if it displays the M mode on the cluster?
12-16-2021, 05:55 PM | #15 |
Rep 19
Drives: BMW 550i
Is this still available?
02-08-2022, 07:08 PM | #16 |
Rep 19
Drives: BMW 550i
Anybody got this Jeezz contact information or email?
He's not responding here. |
