08-02-2020, 07:49 PM | #2 |
Rep 915
Mine would get to roughly 230ish according to Torque Pro. Havent seen any higher.
Instgram @burninja
08-03-2020, 08:12 AM | #3 |
Rep 658
Highest temp I ever saw was 232* but it was typically stable around 228*-232*. I don't like it.
I've contemplated upgrading the cooler upstream of the trans heat exchanger, but then realized that the heat exchanger has an integrated thermostat that would simply stay closed until the temp it needed to open- nullifying whatever cooler temps the upgraded cooler would yield. So therein lies a new question, has anyone messed with the trans heat exchanger thermostat? The thermostat is #10 in the diagram here , but it is not available separate from BMW. Only in conjunction with the cooler itself (#9). I think messing with this (or gutting it if possible? lol) would be the key to getting lower trans fluid temps.
11' M-sport- 371WHP - 478WTQ on stock PWG E50 TunedbyShoup // 386WHP - 429WTQ on Shuenk N55+ with ultra-conservative 91 Octane tune // Starting full-range flexfuel tuning in Spring '24 |
