2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications drive train malfunction today - cylinder 3 trouble
      08-06-2020, 06:40 PM   #1
laurisacpht
laurisacpht's Avatar
Drives: BMW 528i
I was in Eco mode and accelerated and my car went into drive train malfunction mode. I drove about 15 miles to a dr apt and his happened about half way home. So the car ran fine earlier and has not shown any signs of trouble. I just got the oil changed last week. 2016 with 25K miles on it. I cleared the codes and flashed the transmission and the entire system. When I restarted still running rough and drive train malfunction.
140010 misfires more cylinder
140310 misfiring cylinder 3
140001 misfires more cylinders injection is off
140301 misfiring cylinder 3 injection is switched off
running 91 oct tune bootmod3
      08-06-2020, 07:58 PM   #2
paul223
paul223's Avatar
Drives: F10
You need new spark plugs, possibly new coils
      08-06-2020, 08:15 PM   #3
laurisacpht
Drives: BMW 528i
With such low miles and no previous warnings? I find it odd that it happened a few days after an oil change at the dealership as well. Letting the engine cool down and going to pull them and see what they look like. Any advice?
      08-06-2020, 08:18 PM   #4
paul223
paul223's Avatar
Drives: F10
What stage tune?
      08-06-2020, 08:19 PM   #5
laurisacpht
Drives: BMW 528i
91 octane stage one. Tried to pull plugs but need A thin walled 14 mm spark plug socket. Gonna try tomorrow.
      08-07-2020, 09:34 AM   #6
95blkmax
Drives: '11 535 M-Sport
that low mileage by itself typically will not erode spark plugs. But clearly the car sits around longer than average, meaning the fuel in the tank sits longer than average and can turn the fuel bad overtime depending on sitting periods. At 4yrs+ of age of this going on, probably a good idea to get some fresh plugs in there
11' M-sport- 371WHP - 478WTQ on stock PWG E50 TunedbyShoup // 386WHP - 429WTQ on Shuenk N55+ with ultra-conservative 91 Octane tune // Starting full-range flexfuel tuning in Spring '24
      08-09-2020, 11:53 AM   #7
laurisacpht
Drives: BMW 528i
Waiting for spark plug socket to arrive in the mail. Decided to swap coil one and three and clear the codes and now it's throwing an error code in cylinder one so I'm going to replace the coil!
Update! Changed the coil and the error codes cleared. Still waiting on tool to check spark plugs.
      08-09-2020, 06:49 PM   #8
laurisacpht
Drives: BMW 528i
Things are going well now
Socket arrived in the mail and spark plug looks great. All codes are cleared.
95blkmax212.50
      08-10-2020, 03:51 PM   #9
paul223
paul223's Avatar
Drives: F10
FCP euro for plugs and coils, you will never have to buy them again. Just swap out every 20K miles.
      09-07-2021, 02:50 PM   #10
top ramen
Drives: Schwarz II 535i
Old post but want to know what's OP symptoms were thats threw the codes. Have the same codes that popped up last night. I'm running BM3 93 octane stage 1 with transmission flash. Doing WOT at full stop is fine but when doing WOT or giving 60% or more gas above 65mph the car stutters, boggs and shakes than drivetrain malfunction pops up.
Came home, pulled the codes and flash back to stock tune and the car runs normal. Still running transmission flash with stock tune and it runs fine.
Replaced oem sparkplugs about 3,500 miles ago to bosch plugs so I know it's not the plugs. Did symptoms ever come back after replacing the coils? Some people told me the cause is the fuel injectors.
      09-08-2021, 06:51 AM   #11
laurisacpht
Drives: BMW 528i
I was accelerating in normal traffic. Vehicle threw the code and went in limp mode. No other problems she runs like a champ now. Only had her two years and and have had three flat tires. Looking to install auto start soon. I don't drive the car often.
