2010 2011 BMW 5 Series Forum F10 What did you do to your 5 series today? |
09-01-2024, 02:46 AM | #3455 |
Rep 4,048
Drives: 2006 BMW 330i MT
Garage List 2009 BMW 328i Touri ... [8.00]
2013 BMW X5 35i [7.80] 2006 BMW 330i [8.45] 2011 BMW 528i [8.70] 2006 Mazda3 [5.50] |
NikMN2075.50 |
09-01-2024, 02:13 PM | #3456 |
Rep 274
Drives: BMW 550i
StradaRedlands6746.00 |
09-02-2024, 12:19 AM | #3457 |
Rep 1,066
Vehicle: F10
Engine: N55 MFG Date: 06/2014 My water pump failed back in May of this year with 50K miles on the odometer, which made the radiator fan run on high for short bursts every 30 seconds to 1 minute intervals while driving, and finally got tired of listening to it. Everyone outside the car could hear the fan too...got lots of stares at red lights. Pulled the pump off and it's MFG date (5/22/2014) exactly matched 10 years to the day that the pump failed (5/22/2024). Hmm. I was able to slide the pump out from under the car after removing the front sway bar. Just need to rotate the orientation of the pump by 90 degrees, and walk it along the steering rack to the left side of the vehicle, which can also be done on a 4-wheel drive F10 as well. No need to remove the radiator fan. Bled the system, twice, and with a 13VDC Power Supply, the max current draw was no more than 25Amps, so my Sorenson XHR3333 had plenty of overhead. Had to add to add a cheap set of $17 e-torx sockets to my toolkit in short order....didn't realize BMW used this type of fastener head on so many items. Guess I can retire my $1000 collection of 6-point sockets. (I actually needed the 6mm socket for the hose clamps) BTW, the original BMW pump body was hard mounted to the engine block, and now on the newest version, the pump body is rubber isolated. Not sure I can tell a difference, but it did require new longer bolts. BTW, if you are a weekend DIY'er and need a good impact wrench, Home Depot has the 14040 In lbs (1,170 Ft lbs) with the large 4Ahr battery, and charger, on sale for $159.00. This thing is a monster. I tried to remove the sway bar bolts with a breaker bar, and it did not budge. A quick pull on the trigger of this impact wrench and the bolts came off like butter....almost made this project enjoyable. Last edited by M_Bimmer; 09-02-2024 at 01:04 AM.. |
StradaRedlands6746.00 ctcarbonari510.00 |
09-02-2024, 01:03 AM | #3458 | |
Rep 2,651
On a slightly different note, the thing you linked is not a torque wrench it's an impact wrench. Torque wrench typically refers to ratcheting wrenches used to set torque, like this: One word of warning: when doing my diverter valve, I had to take off the bolts for the water pump so I could wiggle it around, and noticed that the thread holes for the water pump strip pretty easily - I could feel it deforming when I got lazy and tried to hand torque it. So be careful.
2015 BMW 535xi
StradaRedlands6746.00 M_Bimmer761.50 |
09-02-2024, 01:05 AM | #3459 |
Rep 1,066
Unspec thanks....was too busy writing the post....fixed in my original post.....
09-02-2024, 01:36 AM | #3460 | |
Rep 1,066
I included a picture with my endoscope of the top mount, and the bottom forward mount (white arrow). With the new rubber isolators, the bolts merely fasten down on metal spacer tube in the middle of the isolator...which I used my 1/4" drive "calibrated" torque wrench on... The water pump ASA bolts, Qty 3, PN 11-51-7-602-123, M8X26-8.8 ZNS3, are torqued to 10Nm, then 90 degrees. Last edited by M_Bimmer; 09-02-2024 at 09:46 PM.. |
09-03-2024, 12:03 AM | #3461 |
Rep 4,048
M_Bimmer You may want to replace the ground bolt while you are down there: https://www.fcpeuro.com/blog/bmw-n55...lt-replacement
M_Bimmer761.50 ctcarbonari510.00 |
09-03-2024, 12:17 AM | #3462 | |
Rep 1,066
I pulled the old pump apart, as it was still pumping water, but it had no comms to the DME, and I could NOT start the self bleed process on the old pump. There three main electronic assemblies.... 1. External connector assembly, that is wire bonded to the MCU board 2. The MCU CCA, which was epoxies into the pump, which was wire bonded to the CAP board 3. The Cap board was epoxied into a cavity in the pump All the wire bonds looked intact, and all the electrical weld tabs were intact. All seals intact, no water in the electronics cavities, so I assume that $600 was all because the MCU CCA communications transceiver was toast. |
09-03-2024, 12:46 AM | #3463 | |
Rep 4,048
M_Bimmer761.50 |
09-03-2024, 12:03 PM | #3465 |
Coal Troll
173
Rep 344
i deleted my rear bumper reflectors with the painted IND ones, for a cleaner look
My hybrid burns Diesel & Oil
deleted F10 535d |
09-03-2024, 03:19 PM | #3466 |
Rep 89
Drives: '15 535i xDrive M-Sport, E30
Finally did a full paint correction. PO clearly liked full-touch car washes and the paint was just dull.
First step was decon, both chemical and mechanical. I started by getting all of the bugs and grime loosened up. Gyeon Bug & Grime and Adams Strip Wash in the foam cannon.
Since the paint was hammered I did a cut and polish.
Last I did a panel prep wipe to get ready for a coating.
Final Results: Overall I'm thrilled with the results and I finally can see the full depth of the Carbon Black Metallic paint. It's not perfect but it's miles better than before. Side note- I'm not new to detailing but I haven't used paint coatings until this year. I did a ceramic coating on my wife's rig the previous week so that experience was still fresh. No high spots on that car but I did see two small spots on my car this morning. Who knows, there could be more but the light has to be just right to notice them. Heres what they look like: Found a trick from the DIY Detail crew (if you've gone past the 12 hr mark, <12 just reapply)- grab some light polish and a mf towel. Hand polish ever so lightly until it's done. If you are gentle enough it should not require re-coating the section. Seems to have worked perfectly (literally took a few seconds). Time will tell if that area fails early. |
09-03-2024, 05:24 PM | #3467 |
Rep 274
Drives: BMW 550i
Looks great. Paint correction is chore to do but results are worth it
StradaRedlands6746.00 s_ribs99.00 |
09-03-2024, 11:56 PM | #3468 |
Rep 1,066
Metallic paint is amazing after paint correction.
09-06-2024, 12:07 AM | #3470 |
Rep 389
Drives: 2015 BMW 535i M Sport
09-08-2024, 07:11 PM | #3471 |
DIY Mechanic
123
Rep 156
Drives: 2012 BMW 535i xDrive
I don't have any pictures but I've been pretty busy lately...I attempted to save my front passenger CV by replacing the boot but it's too far gone. Going to be replacing it very soon...Other than that I have gotten my hands on a copy of ISTA and I've been messing around quite a lot with it. I have reset my engine adaptations, which improved drivability very well. I then also recalibrated my VTG after doing my transfer case fluid change and I also changed my rear differential oil as well. All fluids have been done since the last 10k miles except for power steering. Next up on the plate is replacing both guibos!
You can live in a car but you can’t race a house.
09-09-2024, 03:10 AM | #3472 |
Rep 649
Drives: 2016 F10 BMW 535i M Sport
Just placed a nice order from FCP and ECS, Mainly Maintenance Items, However I finally ordered the ECS Aluminum Intercooler and turbo piping, ordered an Intercooler, got a great deal on it, OFH Bolts and gasket, Oil Cooler gasket and Plugs and O Rings, Intake manifold system gaskets and gasket to DME.
Trans pan and service kit, Differential fluid and plug. Still have more to order! Will post pics when I get to working, A personal Bday gift to myself, to share with you all amazing fellow 5er peepz, lol. Last edited by ChiltiCoatl89; 09-11-2024 at 12:09 AM.. |
09-09-2024, 09:51 AM | #3473 |
Rep 144
Few days ago, took out headlights for polishing and ppf foil, and put uv repellent foil on windows, but just bit darker from oem,i don't like gipsy black window tint on black car.😄😄
NikMN2075.50 s_ribs99.00 StradaRedlands6746.00 ezaircon4jc5669.00 ctcarbonari510.00 Unspec1407.50 cdmulders348.50 SummerallGuard0490.50 |
09-11-2024, 06:15 PM | #3474 |
Rep 649
The goodies are arriving! (Intercooler and box o love 1 of 4)
09-11-2024, 06:43 PM | #3475 |
Rep 649
A little dusty, however came out unscathed during shipping.
NikMN2075.50 StradaRedlands6746.00 |
09-12-2024, 12:47 PM | #3476 | |
Rep 34
Drives: 2021 530i xDrive
I’m really tempted to get this done myself. |
