2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums F10 / F11 5-Series Photos - Video - Media What did you do to your 5 series today?
      12-04-2024, 02:13 PM   #3543
zener
BMW enthusiast since 2004
540
Drives: E65 730d, F10 520d, E34 520i
Washing day for 5 and 7. Inside to outside.
zrile142.50
      12-11-2024, 05:19 AM   #3544
ChiltiCoatl89
ChiltiCoatl89's Avatar
Drives: 2016 F10 BMW 535i M Sport
Got my Custom 20s" Staggered wheels finally installed, sitting on Continentals again (DWS06)(Same as my 19s just sized and fitted for 20") washer cap, fuel cap and oil filler cap, and Oil service performed today, new oil filter housing cap as well.
NikMN2024.50
cdmulders348.50
zrile142.50
      12-11-2024, 12:48 PM   #3545
zener
540
Washed it and had to lift it a bit.
NikMN2024.50
s_ribs99.00
cdmulders348.50
zrile142.50
      12-11-2024, 05:01 PM   #3546
Smonkbmw
Drives: 2013 x5 m57
2013 BMW x5 35d  [0.00]
Ordered a NOS set of H&R Coilovers for $1100!!! Compiling a list of parts and “while you’re in there’s” to make it a quick swap.
      12-11-2024, 10:25 PM   #3547
ChiltiCoatl89
My 5er After hand wash, and also today, conditioned my leather and detailed the plastic and other bits.
NikMN2024.50
cdmulders348.50
      12-13-2024, 04:43 AM   #3548
hrvojexyz
Drives: BMW F11 535dA `12
I found out that the sun shades, on the small window , rear left door, which are I supose are some sort of aftermarket made..
Are missing one of those small hooks . Was searching aliexpress, found something that might help but not exact thing.
It isnt like original one , but have no idea where would I find it.
zrile142.50
      12-16-2024, 01:36 PM   #3549
ChiltiCoatl89
Washed before Vacay, day picture to see those wheels shine. (Love that Carbon Black).
NikMN2024.50
s_ribs99.00
      12-16-2024, 03:26 PM   #3550
zener
540
Installed the new ac panel for comfort seats with cooling that are arriving tomorrow. Also coded it to my current setup so seat heating works. New buttons are on the way also.
      12-18-2024, 02:51 AM   #3551
ChiltiCoatl89
Exterior detailed after a few days after my hand washing, vendor at shopping mall. Enjoying Vacay.
      12-18-2024, 02:04 PM   #3552
zener
540
Recoloured upcoming seats.
NikMN2024.50
zrile142.50
      12-20-2024, 01:27 PM   #3553
xxpanipuri
Drives: 550i
have you tried leatherique to clean them?
zrile142.50
      12-20-2024, 01:41 PM   #3554
xxpanipuri
Drives: 550i
All done in the ln the last week
96k miles!
Oil Change
Ran 2 cans of LM Engine Flush for 20M (after warming the car up for 15m)
Drained oil - refilled with LM Oil + LM Motor Oil Saver
first oil change with Valvo Max Drain
This is life changing!
https://www.valvomax.com/?srsltid=Af...WumS5O_TVu2lNH
2 new front Mich PS4S (245/35/20)
new rear pads/rotors (oem)
with this 40 degree cold (for bay area) weather She's ready for some 60-90ish freeway pulls
In the last 20k miles
8 new injectors
4 new cam position sensors
4 new o2 sensors
4 new vanos solenoids
2 new HPFP's
2 new maf's
+ new turbo coolant lines
new lower lower tension bars (front)
new pads/rotors - Front / Rear
      12-20-2024, 01:44 PM   #3555
zener
540
I washed them before colouring, also used the cleaner that came with colouring kit. Drives seat leather was just worn.
Second picture is after painting and dark areas are shadows.
      12-21-2024, 09:52 AM   #3556
Hoa
For your next oil change, could you pull the Valvo Max Drain off after draining with the valve and see if more oil will come out. I suspect it traps oil because if the threaded area is longer than the thickness of the oil pan, it would create a lip inside of the pan blocking oil from coming out.
      12-22-2024, 12:50 PM   #3557
zener
540
Installed comfort seats and all coded, but apparently the modules I bought are too old. Also passenger occupancy sensor problem too. Is this related to seat module being too old? Or does acsm needed to be coded also for comfort seats?
Also might need to track down lower seat heating element for drivers seat. Everything else works but ventilation does not activate at all from ihka.
      12-22-2024, 03:19 PM   #3558
Unspec
Unspec's Avatar
1403
Drives: 2015 BMW 535xi
ACSM must be coded to enable the active headrest protection thing-y. You'll need to run two wires from each seat to the ACSM.
The seat detection might also be due to lack of wiring - the comfort seats are only plug and play if you already had fully electronically adjustable seats for the seat being replaced. If you only had partially electronic adjustable seats (e.g. for the passenger) there's a lot of wiring that needs to be done.
2015 BMW 535xi
ISTA VM Setup/Tutorial
      12-22-2024, 03:31 PM   #3559
zener
540
I had fully electric sport seats with memory. And now everything else works apart from ventilation, due to modules being too old. Occupancy sensor is kinda of solved as the sensor is different after 09/11 (mine is 03/11) and seats being from 09/12... It is good that on eu cars occupancy sensor is only used for seat belt warning so, might have to get the emulator and code out the seat belt warning from passenger side (or go with route to change older style occupancy sensor in to the seat)
I already had active headrest protecion on my sport seats as I compared seat plugs (and looking from TIS) and was only missing pin1 to power up the seat switch on both seats.
      12-25-2024, 03:05 PM   #3560
zener
540
Recoloured the center armrest... But still would be nice to have new leather on it.
Also looking for cooled comfort seat lower cushion as drivers side lower part does not heat up. Backrest heats up nicely.
      12-26-2024, 10:15 AM   #3561
zener
540
Tried to figure out more why the seat cushion does not warm up. I guess the drivers seat cushion heating mat is just broken. measures close 10ohm and does not change at all with temperature. Ista says 1,5-4ohm. Passenger side resistance changes a bit when you are measuring and it works.
Also found the usual place that wire burns to be fine on my seat.
      12-29-2024, 03:03 AM   #3562
Carbon535i
Carbon535i's Avatar
Drives: 2015 BMW 535i xDrive M sport
Still haven't gotten off jack stands yet, but so far:
- Replaced the suspension.
- Added Downstar inc. dress bolts and washers to the skid plate and fenders.
-Painted the stiffening plate.
- Much more to include today of fixing the nightmare of a wiring mess the previous owner left when it appeared they tried to run a dual lpfp setup. I cleaned up the wires and installed a Arc Terminator EKPM3 cooling fan and soon will be installing a BimmerHausPerformance Transfer case bushing insert and Arc Terminator ground cable after I remove and paint the crossmember.
      12-29-2024, 03:30 AM   #3563
ChiltiCoatl89
Very nice Carbon! excellent mending work!
      12-29-2024, 03:48 AM   #3564
Carbon535i
Carbon535i's Avatar
Thank you Bro!
