2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes Anyone running non-OE TPMS?
      03-10-2021, 10:11 AM   #1
ferizzo
Drives: 2016 BMW 550xi M-Sport
Hey folks,
I am preparing to purchase new wheels but plan on keeping my Stock rims as winters. As my title states, wondering if anyone is running non-OE/OEM HUF TPMS on their wheels. If so, any issues? Have tried researching on here with little success. Looks like the stock TPMS are 433mhz but is this the only criteria in purchasing? Tirerack seems to have some 433mhz that fit my 550 but just checking to see what folks are using. TIA
      03-10-2021, 12:13 PM   #2
Originally Posted by ferizzo View Post
Hey folks,
I'm running Costco sensors in our 2012. No issues as long as you get the correct frequency sensors.
YMMV
ferizzo84.00
      03-11-2021, 12:24 AM   #3
Bounceme
Bounceme's Avatar
Denmark
111
Drives: 2016 F11 520d LCI
Mine are Autel MX-sensors, and i havent had any issues
      03-12-2021, 01:34 AM   #4
Unspec
Unspec's Avatar
1380
Drives: 2015 BMW 535xi
As long as it's 433, it'll be fine. You might lose temperature sensing and only get pressure though.
2015 BMW 535xi
ISTA VM Setup/Tutorial
      03-12-2021, 01:08 PM   #5
ferizzo
Interesting...didn't know we had a temp reading. I ended up getting some from Ebay that appear to be from HUF. We'll see how it goes.
Thanks folks!
      03-12-2021, 01:26 PM   #6
OnlyGerman
OnlyGerman's Avatar
Drives: Too many German broads
Thanks folks!
Temp reading can be coded if supported by the sensor
      03-26-2021, 08:59 PM   #7
steven1800
Drives: BMW 528i
Piston retraction doesn't work
Hello, need some help here - I accidentally press the pedal when I was changing the rear pad, now the piston coming out a lot and could not be pushed back.. the caliper is with electric brake module, I have followed you tube trying to screw electric part back then use c-cliper tool to press/screw piston back, but it doesn't work.. any idea ?
      03-29-2021, 08:00 PM   #8
dzz
Drives: 2015 BMW 535xi, MHD Stage 2+
2015 BMW  [0.00]
Hey folks,
you'll need to reset TPMS in your car to detect sensors in new wheels
      04-20-2021, 01:01 PM   #9
KaiserWil
Drives: BMW 520d
Hey folks,
Yes, I had them installed ( 35 euro a piece ) and they work great.
