2010 2011 BMW 5 Series Forum F10 MHD Antilag for F series n55's |
02-08-2021, 11:07 PM | #23 |
Rep 5,365
02-09-2021, 06:06 AM | #24 | |
Rep 1,873
It was likely actually in the low 200s as it sat with some stuff added to it, and it was a way more engaging driving experience in pretty much every way, but anyways.... It just seems like there was more engineered headroom for launch shenanigans and whatnot in that driveline than in what I've got now. I believe xHP unlocked LC on my pre-LCI, it offers a couple of pages of sliders to tune its behaviour - never even tried it. |
02-10-2021, 10:37 AM | #26 |
Rep 1,442
Drives: 2011 535i 6MT
Thanks! I just came here to see if burbles were fixed... I'm a developer and I understand the release notes don't always tell the whole story LOL - if they did you'd have to admit everything you did wrong...
ey2001310.00 |
02-10-2021, 12:24 PM | #27 | |
Rep 2,591
Bug fixes and improvements
2015 BMW 535xi
02-10-2021, 04:12 PM | #28 |
Rep 1,442
Any word on when the anti lag will be fixed for the f10?
02-10-2021, 04:21 PM | #29 |
Rep 716
02-10-2021, 10:01 PM | #31 |
Rep 1,299
I would be careful because this is generic anti-lag vs something that is tune for your specific setup. I would highly go against doing this on stock motor but it's your car your choice I guess. The way David Shoup explained this effects the button end of the motor the most which means this can potentially cause rod bearing failures or more.
95blkmax212.50 |
02-11-2021, 08:43 AM | #32 | |
Rep 658
Certainly this is no fix for that (going off on a related tangent here)... but this is exactly why on these tuned cars you do NOT stick to BMW's ridiculous oil change interval. Change your oil often. It will not avoid you from eating up your rod bearings, but it will help to reduce how much damage they take.
11' M-sport- 371WHP - 478WTQ on stock PWG E50 TunedbyShoup // 386WHP - 429WTQ on Shuenk N55+ with ultra-conservative 91 Octane tune // Starting full-range flexfuel tuning in Spring '24 |
02-11-2021, 09:17 AM | #33 | |
Rep 1,299
02-11-2021, 09:40 AM | #34 |
Rep 658
same! 3000-3500mi. Especially since I run E30. Ethanol tends to add moisture in the crankcase so at a 10k mi interval it makes the oil APPEAR as if it was mixing with coolant (milkshake). I don't need that moisture getting into the tight film of oil at the rod bearings lol
02-11-2021, 10:31 AM | #35 |
Rep 1,873
Maybe I don't get *when* rod bearing are supposedly being impacted. During the actual anti-lag operation, combustion is taking place after the cylinder making for all the noise, flames and all that stuff the kids like. This is hard on the exhaust, turbo, and all the related plumbing. On the rolling shots, there isn't even any acceleration taking place - explain how the rod bearings are in peril? They're barely loaded.
Now, if you have your foot deep in the throttle and you release the anti-lag button, then you're suddenly making a lot of power. However, I don't know how "suddenly" it seems to an engine already spinning at 3k. The piston is changing direction 100 times per second - the acceleration feels "sudden" to the vehicle occupants but to the rod bearings is it really any different than stomping it to the floor from a stop? Or lifting and reapplying the throttle suddenly on factory code? (turbo still spooled naturally) I'd be more worried about cooking the turbo, destroying every cat in the car etc... |
02-12-2021, 08:19 AM | #36 | |
Rep 658
The issue Im concerned about is people setting the antilag to 12psi at 2500 rpm (if that's even possible on the app... I've yet to take a look at it). It's a matter of engine load. Same reason you don't do a 100-shot of nitrous off idle, or go WOT on a turbo's NA engine below 3000 rpm. That amount of load is killer on the bottom end. That's how other engines throw a rod out the block lol. That and being that early N55s like mine (I believe it's 2014 and back) have cast pistons and rods, it's not something I'd want to play with. You can certainly do it but I'd go higher up in the rpm for it like 3500-4000. Anywho, that kind of load on the bottom end really tests the quality of the oil. As the rods dont rub, but "float" on a thin film of oil between the rod end and the crank journal. If load is too sudden and too low on RPM- especially with degraded oil, the driver runs the risk of the load pushing the piston hard enough to "squeeze the oil film" off the mating surface and make hard metal to metal contact. This is instant spun bearing situation and now this driver would have rod knock.
02-12-2021, 09:00 AM | #37 | |
Rep 53
If there really was a true concern about loading up an engine at low rpm and beating up the bottom end, then you shouldn't run any aftermarket tune on an N55. If you look at the dyno graph of any tuned n55, they basically make peak torque and boost at 2500rpm. This is just the nature of the tiny turbo that's on this engine. If beating up the bearings/bottom end was really that big of a concern then the "tuners" would have a totally different boost curve to flatten the torque output of our engines. I can put my car in the highest gear, at 25mph, floor it and probably put way more load on the engine, for longer, than anti-lag would. Regardless, the anti-lag feature for stock turbo engines isn't really a big value add. I can understand if you have a turbocharger upgrade, but the stock turbo is so small and spools so easily that I don't think it's going to make that big of a difference. Hell, you can free rev a stock turbo n55 and it'll make boost. I think it's going to be just like burbles. It makes pops and bang noises, sounds cool to the kids and they can talk about "anti-lag bro". I don't have MHD so I'm not sure how it works, but if they were really concerned about you damaging your engine, they would likely set a limit on how long or how often you can use it. Honestly if you sit on the anti-lag long enough to damage your engine then you kinda deserved it lol. Just my thoughts on it |
T-Bone1822.00 |
02-12-2021, 11:01 AM | #38 |
Rep 1,442
Good call on all your points there, and they DID set limits on this. It will only hold boost for a couple seconds and then release it - meaning if you don't launch it releases boost - so you can't sit on anti-lag. And I was watching my boost gauge, even at lower rpms I can make 12 lbs of boost pretty quick, so how much advantage this will gain you could be pretty minimal since we have small, quick spooling turbos. So I also agree that bigger turbo'd cars would see more of a difference with this. Which is yet another reason why I don't think this will be the destroyer of the bottom end!
02-12-2021, 02:58 PM | #39 | |
Rep 658
02-12-2021, 03:13 PM | #40 | |
Rep 658
02-12-2021, 08:26 PM | #41 |
Rep 2,591
I think this feature brings up an interesting question. Knowing the availability of this feature, and that many owners are not exactly gentle on the cars to begin with, how would this affect future buying decisions? I feel like I'd definitely stay away from cars that have been MHD/BM3 tuned since there's no real way to see if they've abused the anti-lag feature or not.
2015 BMW 535xi
02-13-2021, 08:26 AM | #42 | |
Rep 1,442
02-13-2021, 08:28 AM | #43 | |
Rep 1,442
02-13-2021, 04:24 PM | #44 | ||
Rep 716
