2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications N55 Cam Upgrade ?
      02-07-2020, 12:59 PM   #1
bigscore
Drives: BMW F10 coming soon
N55 Cam Upgrade ?
Have any of you guys seen this?
Thoughts.....?
      02-08-2020, 03:33 PM   #2
Rob09msport
Drives: 09 335 msport
I know that some guys use the n53 head cause it has di and it flows way better than n54 anyway so would make sense that the n52 cam on n55 would do the same
      02-09-2020, 02:55 PM   #3
kimoboy
Drives: E90 335i
I know the owner of this car and he told me that the N53 cam makes good power.
Thoughts.....?
      02-10-2020, 08:46 AM   #4
e38740imd
Drives: 2016 640i
its discussed in the f30 forums
      02-10-2020, 10:29 AM   #5
MaximumFreckles
Drives: 2011 BMW 535i Msport
So is the N52 cam a worthwhile and viable swap for those of us on a stock turbo with upgrades? Judging from the power it makes throughout the powerband, especially up top, it seems like it would be. Fairly straightforward job. Obviously I would not expect those kind of gains unless I had a stage 2 turbo, but it seems like this would be beneficial for everyone. Would love to hear from those that are more versed in the technical aspects of this engine.
      02-10-2020, 10:44 AM   #6
BrowBMW
Drives: 2011 535i 6MT
Looks like some pretty solid before and after data. Kinda hard to argue with... Looks like a good upgrade. Not just the #'s but the power band shift is great.
2011 535i 6MT Currently: MHD stage 2+ flash on 93, BMS Intake, BMS Charge pipe, high flow sport oil cooler value, billet oil thermostat cover and oil filter cap, CDV Delete, Armytrix CLDP and full exhaust, Short throw clutch stop, Wagner Knockoff FMIC, H&R f&r sways, various black and CF exterior upgrades In the works: Redshift Coil Overs, Strut tower bar Coming soon: Turbosmart BOV, sprint booster, LSD, DIY Ram Air Intake?, short shifter
      02-10-2020, 12:36 PM   #7
Unspec
Unspec's Avatar
Drives: 2015 BMW 535xi
Here's a pretty long discussion on it on spool street.
https://bmw.***********.com/threads/...n-an-n55.5722/
Overall, I don't know if it's worth the money.
Edit: Replace the * with spool street. Minus the space. Is spool street censored on this forum...?
2015 BMW 535xi
Bootmod3 Stage 2 | ER Catted DP | Remus Exhaust | Gplus FMIC
      02-10-2020, 03:55 PM   #8
BrowBMW
Wow, can I have the last 45 minutes of my life back now? Finally they got to some decent data, but... just... wow. I'm not going to post over there anytime soon.
      02-10-2020, 09:28 PM   #9
Unspec
Unspec's Avatar
Yea to be honest it seems like people just yelling at each other back and forth, and the kinda technologically clueless OP of the video didn't help. He couldn't figure out how to submit logs to datazap and had someone else do it lmao
2015 BMW 535xi
      Yesterday, 11:33 AM   #10
95blkmax
Drives: '11 535 M-Sport
Alright just because I let numbers speak rather than opinions, I went and did some quick research and I pulled this information from MyWikiMotors.com so take it with a grain of salt, BUT....
N55 CAM SPECS
Duration 255 INT/261 EXH
Lift 9.9mm INT/ 9.7mm EXH
N52 CAM SPECS
Duration 255 INT/ 263 EXH
Lift 9.9mm
Again, I am not certain of the validity of this information. But unfortunately this is all I've come across. Does anyone have any different information that'd want to share?
Because (again, just based on this one website's information) this doesn't seem like a worthwhile improvement for the labor involved. The INT cams spec identical. The SLIGHTLY longer duration & SLIGHTLY larger lift on the EXH cam would spool the turbo quicker, but as for actual power... idk
Share your data please! I'd love to see an actual before and after dyno too! lol. This is all the data I have to go off on and it's not looking promising based off of it.
11' 535i M-sport- Intake/ IC/ CP/ Catless DP/ JB4/ Hawk HPS Pads/ BimmerCoded/ CF Exterior Bits
      Yesterday, 01:21 PM   #11
BrowBMW
Did u read that huge thread on the other site? They go through the same argument and have done the research. Let me save you the pain: from a data standpoint adding the cam was NOT the only change. He also retuned the car that was previously on a bad tune. So with more than one factor his results were invalid.
I spoke with a tuner and he said he could get me 30-40 HP over the OTS tune from MHD, if I added an air intake at the same time I couldn't attribute all the added HP to the intake!
      Yesterday, 01:51 PM   #12
95blkmax
HAHA dude I completely flew right over the link to that other thread . Well thank you for the clarification. It was a nice way to kill half hour at work
      Yesterday, 02:46 PM   #13
ziekxq
Drives: 2011 535i xDrive
The only real upgrade is remove n55 and install s55.
Copyright ©2000 - 2020, vBulletin Solutions Inc.
