2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications N55 twinscrol turbo broken
      05-08-2019, 06:40 AM   #1
Marcogs12
Marcogs12's Avatar
Drives: 535i F07
Hi everybody,
New in this forum to share my unfortunate experience with my BMW 535.
At 83000km the turbo broke.
I would appreciate to get your comment on how this may happen.
      05-08-2019, 08:37 AM   #2
Stück
Stück's Avatar
Drives: F15 X5, E46 330i, R56 Mini.S
That turbo ingested foreign debris. Plain and simple.
      05-08-2019, 10:21 AM   #3
ziekxq
Drives: 2011 535i xDrive
Also, how often did you do oil changes and what gas you use? I think those also factor in but I could be wrong.
My stock turbo came out looking pretty much spotless when I upgraded my turbo to ps2. I do oil changes every 4k to 5k miles and only put 93 oct from shell:
https://m.imgur.com/a/GjdT9Rr
      05-08-2019, 10:47 AM   #4
paul223
paul223's Avatar
Drives: F10
Turbine wheel was grinding against loos metal or rock debris. It seems like I have seen this turbo on Ebay.
      05-08-2019, 02:29 PM   #5
ziekxq
In anycase, I think he is better off getting a used cheap turbo from ebay and than trade that in for pure stage 1. Its cheaper than new original turbo from bmw.
      05-09-2019, 03:03 AM   #6
bimmer_mods
Drives: E60 & F10
That looks good! I'm curious at what mileage was that?
      05-09-2019, 06:49 AM   #7
ziekxq
90k miles
      05-09-2019, 06:55 AM   #8
Marcogs12
Marcogs12's Avatar
Drives: 535i F07
Thank you for all your comments.
In the mean time I contacted BorgWarner (BMW turbo manufacturer) and they gave me the same explanation. It is probably due to a foreign object swallowed through the air inlet. I still have to check the air filter, air box, air inlet and intercooler for any loose object.
Oil is changed every 10000 km and I use 95 oct.
Mileage is 83000km (not miles)
      05-09-2019, 06:58 AM   #9
Marcogs12
Marcogs12's Avatar
Drives: 535i F07
Here is the answer from BorgWarner.
They provided interesting links for Turbo troubleshooting.
Dear Sir,
based on the photo the possible turbo failure reason is a foreign object on the compressor inlet.
Possible causes:
• Nuts, washers, etc. forgotten during engine service
• Pieces of air intake system coming loose
• Pieces of deteriorated or non-fitting gaskets
• Inadequate maintenance of the air filter and air supply systems
• Particles in the air inlet
• Loose hardware or other foreign material
Please find attached the diagnostic matrix for further info and see links below:
https://www.borgwarner.com/aftermark...roubleshooting
https://www.borgwarner.com/docs/defa...sn=f680b63c_18
Kind Regards / Mit freundlichen Grüßen
Matthias Kipper
Technical Support Engineer
BorgWarner Aftermarket Europe
      05-09-2019, 07:02 AM   #10
Marcogs12
Marcogs12's Avatar
Drives: 535i F07
Now looking to repair the turbo with this cartridge from E Bay.
Is it an acceptable solution when you see it is manufactured in China
      05-16-2019, 10:12 PM   #11
NinetyEight740
NinetyEight740's Avatar
Drives: 2 - 2013 535i msport
2010 E91  [0.00]
For sure sucked something up. Anyone recently working under the hood of your car? Spark plugs? Valve cover gasket?
      06-17-2019, 07:07 AM   #12
Marcogs12
Marcogs12's Avatar
Drives: 535i F07
Finally my car is back on the road.
After checking all pipes and intercooler, I did not find any foreign object of any sort except the debris coming from the broken compressor. The air filter was in good condition.
I installed a second hand BMW turbo and the car is now running as before.
I just cross mi fingers it does not break again.
