2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes Car looks bent
      12-19-2018, 10:45 AM   #1
bgbQ8
Drives: 530i F10 2013
Update : Fixed
The car has been pulling to the right for the past 6 months. Around that time I also noticed that the right rear tire looked bent with the whole right side not looking straight. So i went to the dealership this past week and they told me I had cracks on my thrust rod bushes and wishbone lower control arms. So they changed them both and did the alingment. Now the pull is gone but the rear wheel still looks bent from the back.
Ps I didnt get into major accidents so I dont think its my frame. Atleast I hope so.
Update FIXED : May 2019, after putting the car on a frame machine. It turned out that the subframe shifted a bit to the back. Then they had to put it back in place.
As of now the car has NO pull. It doesnt look bent when looking from the back.
If anyone gets into alot of alignment issues. And regular tire shops or dealerships that cant pinpoint the problem. Go to a certified bmw body shop and they will align ur car like its new.
      12-21-2018, 01:30 PM   #2
BurrNinja
Looks like the right rear is going in from my pov. Driver rear doesnt match passenger side at all.
Instgram @burninja
      12-21-2018, 01:37 PM   #3
Personally, with all the reflections I can't see what you're saying/seeing.
      12-22-2018, 07:16 AM   #4
lsturbointeg
lsturbointeg's Avatar
Drives: 2011 535i Jet Black
+1 post some better pictures
also, according to the spec sheet the camber looks within specs
      12-22-2018, 01:50 PM   #5
BurrNinja
From the picture thats what I see, its hard to tell without physically being there. Try measuring the tire to fender length on both sides and check the difference, also you can use a string from the front to rear on both sides make it square though and measure. Set up 4 cones or whatever to hold the string and see if it is unaligned.
Instgram @burninja
      12-22-2018, 07:10 PM   #6
Duckysaurus
Duckysaurus's Avatar
42
Drives: 2021 G05, 2014 F10, 2009 E90
2014 BMW 535xi  [8.50]
2009 BMW 328i  [0.00]
Passenger side, rear wheel looks like it's toed in (angled towards the centerline of the car facing the front).
Even if the car is running straight, you'll want to get that fixed if possible. It'll wear quicker than your other three tires.
      12-24-2018, 08:44 AM   #7
Surly73
Every BMW I've ever had has rears that look like that. Some body style curves at the rear wells accentuate it more than others. Toe in and negative camber at the rear is normal, in the spec, and that's probably all you're seeing. Take some comfort that you have a fresh alignment report on hand that says everything is fine.
It is still true that this specification wears rear tires faster, but that doesn't mean something is broken.
      12-25-2018, 07:24 AM   #8
lsturbointeg
+1
I have a slight and I mean slight camber but I requested to have the wheel as flat as possible when I had my alignment done just to improve the longevity of the tire and not having that inner camber wear
      01-09-2019, 03:15 PM   #9
InHousePerformance
InHousePerformance's Avatar
Drives: 2015 535i
2018 Ford F150  [0.00]
2015 535i  [0.00]
BMWs are known to have negative camber coming from the factory. Most find themselves replacing tires when they look good from the outside but when you take the wheel off and look on the inside of the tire you have excessive where compared to the rest of the tire. When you get the car aligned ask them to try to get your camber as close to zero as possible.
2015 F10 535i
FBO BM3
Pure Stage 2
Dorch Stage 2 HPFP
E50 tune by Cary Jordan
EOS EkP Module
Walbro 525 LPFP
Variant Argon 20? Wheels
E60 M550i Sold
“Im a crazy car guy”
If it has a motor, it has my attention
      01-10-2019, 04:05 PM   #10
sesh1957
Drives: 2012 535i xdrive
I think we need 4 wheel alignment so it should show with alignment if it is off.
