07-06-2019, 03:42 PM | #1 |
Rep 441
Wagner IC install notes
Bullitts5's DIY for the G Plus told me everything I needed to know going into it. I def second his "tight fit is an understatement."
So much so that I don't think we could've gotten it in there without a using the jack. We got it lined up as best we could and slowly but surely crammed it up there with the jack, used a flathead to pry the edges away from obstacles, and hoped we didn't break anything...didn't feel like there was any other choice. The stock IC has a tab that rests on a plastic shelf and we couldn't budge the Wagner forward AT ALL in order to slide it around and back onto that shelf, so we ended up just pushing straight through the shelf and kind of breaking it. So the metal brackets, and belly pans, are the only thing holding it up but I think that's fine. Once it was up and into place the hoses almost clicked into place themselves. Passenger side very easy to lock into place, driver side a bit tougher to get hands up there. The drivers side also had a coolant(?) hose that was directly in the way of the pipe connection so we had to squeeze/push that behind a mount that was right there...tight squeeze but needed to get it out of the way. The drivers side boost pipe that connects to the IC has a clip mount that you can reach from the top of the engine bay, we unclipped that to get a little more play in the pipe. Worth it. We kind of shook our heads afterwards, and figured if we were doing it again we'd just make sure the path was clear of hoses etc and not think twice about ramming it up there with the jack, and it'd be a super quick job. Now I'm finally fbo - my Wedge custom tune hits my inbox any minute! |
07-06-2019, 05:13 PM | #2 | |
Rep 590
07-06-2019, 10:37 PM | #5 |
Rep 716
After Wagner intercooler
https://datazap.me/u/ey2001/after-fm...8;data=4-11-22 Before https://datazap.me/u/ey2001/3rd-gear-dsc-0 |
07-06-2019, 11:26 PM | #6 | |
Rep 75
07-07-2019, 12:08 AM | #7 |
Rep 60
The G-Plus that I installed was TIGHT, had to cut off a piece of plastic on the back side of the shroud to get it to slide in. Overall it works, we broke the clip that goes from the turbo to the intercooler, but I ended up finding the clip online and re re-did it, second time around was a breeze. I have the FTP boost pipe on the passenger side and stock one on the left side, when we oiled everything up, the passenger side ended up being the easier side, the driver side was actually not bad as well since we complete removed it and installed it after we put in the intercooler, just had to "snake" it through, but but IATS are a whole lot better and getting about 6 MPGs better than the stock intercooler! I would go with the G-Plus and save the $600 bucks, but if you wanna go Wagner, go for it, but from reading reviews and actually seeing the G-Plus in person and installing it, it's identical to the Wager
2014 535i M Sport Mods: BMS Intake, FTP Charge Pipe, FTP Boost Pipe, G-Plus FMIC, JB4, Remus Sport Exhaust with 84mm Black Carbon Tips
07-08-2019, 01:12 PM | #8 |
Joint Chiefs of Staff
24186
Rep 190,777
Congrats OP!!
