2010 2011 BMW 5 Series Forum F10 Valvetronic system deactivated *FIXED* |
02-02-2023, 01:10 PM | #1 |
Rep 179
Drives: BMW 535i F10
Got this error - 133E10 Valvetronic system: Deactivated, adjustment fault too frequent.
Is there any way i can check if valvetronic servomotor really needs to be replaced? |
02-02-2023, 11:12 PM | #2 |
Rep 1,356
You can purchase a new motor and plug it in to test. Just unplug the old one and plug the new one in your hand. Motor should move if your DME is ok. I actually have the motor for a N55 if you want to purchase from me. I purchased it from a local dealership and never returned.
Based on personal experience, wiring is not the issue. Either the valvetronic motor is bad or DME is bad. My X5 had a bad DME. It would not send power to the valvetronic motor. |
StradaRedlands4939.00 |
02-04-2023, 06:49 AM | #3 | |
Rep 179
UPDATE: I tried to reactivate the Valvetronic by ISTA and it could successfully relearn but after driving a little I got the code 133B04 - “Valvetronic system no adjusment possible”. Does that mean that only Valvetronic motor is faulty and not the shaft if it could relearn? Before i buy and swap the motor i want to make sure if it is the real cause of the issue because the labor isn’t cheap.. I found on ISTA that battery i have is 90 Ah instead of 105 Ah - could this be a cause of any problem? Probably Valvetronic motor not getting enough power supply? Or changing the Valvetronic motor is only way to check if it is faulty? |
02-04-2023, 09:12 AM | #4 |
Rep 1,356
Battery will not be the issue. Make sure you code it for 90 so it knows how to charge the battery corrrctly.
It could be that the motor is bad. No way to tell for sure unless you swap it out. The shaft does fail but less than the motor. I do not know about recall. You would have to check with BMW. |
lukavergille206.00 |
03-27-2023, 02:08 PM | #5 |
Rep 3
Hey Folks, I am seeing this error in my bimemrlink app info memory but not in permanent errors. Should I be worried?
Just FYI, battery life is low for my car (60%). So I am planning to change the battery soon and there is no check engine light and car drive normal. |
03-29-2023, 04:01 AM | #6 |
Rep 458
If battery was an issue you would get a cold start servo error which would likely happen around 12v-ish. When the car is running if the battery is low you should see the alternator kick in 14.7v. Having said that, if the battery is bad then you’ll see lots of error codes that could cause issues.
Lastly, 90ah battery is fine. The 105ah was to provide more reserve power between charge cycles. |
05-15-2023, 07:07 AM | #7 | |
Rep 1
05-20-2023, 03:57 AM | #8 |
Rep 179
Sorry didn’t have a chance to post the update - the error still came up and finnaly had to replace the valvetronic servomotor. Bought the one from totalled car with 50k miles for $100. One tip: if you replace the motor the code might still show up and you will need to reactivate the valvetronic from ISTA for it to work again.
Probably my servomotor still had some life in it and that’s what lead me in believing that fixing a low oil level solved the problem but the problem came back like 300-400km later and that’s when i changed the servomotor. Will delete my post about adding oil to not misguide anyone. |
