2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications jb4 iso
      11-05-2018, 05:46 PM   #1
Bts535i
Drives: 2012 535i xdrive
jb4 iso
so I cut the diode and updated to iso on my 2012 535i. I changed the settings as specified and my car is running like shit. boost is inconsistent running rich and wg is all over the place.
was running great before I updated to get the gas pedal mapping.
can I return to the previous firmware seeing I already cut the diode?
      11-06-2018, 08:28 PM   #2
5soko
5soko's Avatar
335
Drives: M5
Post this over on the jb4 forums for help specific to you..
Current: E63S AMG 4matic RENNtech || M5 Evolve..Eventuri || F10 LCI 535i MHD
      11-13-2018, 06:44 PM   #3
obiltagi3
V.I.P.
obiltagi3's Avatar
Drives: F10 535i 2011, F10 550i 2015
2015 BMW 550i  [9.00]
Can you take a picture of your jb4 board and post it here? Have you tried to load the firmware again and make sure it "successfully updated"?
Ideally, you can revert the board to original but will need to solder the one diode leg back on. Just be very very careful when soldering.
F10 550i Imperial Blue/Ivory
BM3 Stage 1 - xHP Stage 1
F10 535i Alpine White/Oyster
BMC - Vorsteiner Exhaust - ER Chargepipe - AR Catless DP - MHD Stage 2 - FMIC
      11-13-2018, 07:20 PM   #4
Bts535i
thanks. I posted over at n54tec and the guys helped me out.. had me change a few settings and the car is running much better.
if I were to reconnect the diode I'd my brother do it.. he use to build computer boards
      11-18-2018, 02:33 AM   #5
obiltagi3
V.I.P.
obiltagi3's Avatar
Glad you figured it out!
      12-30-2018, 06:16 PM   #6
Bts535i
soldered the diode back on tonight and switch back to Integrated firmware from ISO and my car runs so much better..
the power is smoother and feels more consistent.
should I still do a def?
      01-06-2019, 05:28 PM   #7
Sylverlee
Drives: White 535i M-Sport, 911 GTS
What were some of the things N54 had you do to smooth out the power? I just installed a JB4 with ISO and I'm getting the inconsistent delivery. Not sure if it's with the Gas Pedal Mapping or the change in duty cycle.
      01-06-2019, 05:37 PM   #8
Bts535i
everyone is different. I dont have your logs and dont know how to guide you.
they had me change a few things but that was based off my log I provided.
I wish I could help you but I dont wanna tell you what numbers I changed and have them mess you up.
my best advice is post a log.
I changed settings based on my log and it did help smooth things out but i did end up soldering my diode back on and downloaded n55 pwg hex 11.
i run map 1.
I love the spree spool with the wastegate position.
I get great low rpm boost in sport mode for great throttle response in city driving..
if you dont have a turbo upgrade and dont want to continue playing with settings I suggest you go away from iso and back to integrated firmware.
      01-08-2019, 10:04 AM   #9
Sylverlee
I see. That's a good recommendation from what I'm experiencing with ISO. Similar to your story. How easy was it to solder back?
      01-08-2019, 11:03 AM   #10
Bts535i
depends on where you cut it and if you have any of the wire long enough to solder it.
bms will solder it for you if want to send it to them. or go to a local computer repair shop they can do it quick
