2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications BMS PEDAL TUNER vs SPRINTBOOSTER
      11-02-2018, 07:35 PM   #1
sweettalker
Drives: Vrooom
Anyone have any reviews on the bms pedal tuner for the f10?
Prefer someone whos had both sprintbooster and pedal tuner but im sure thats going to be rare.
Any input would be apprecoated.
I am on the fence between the two.
      11-03-2018, 10:21 AM   #2
kohsin
Drives: 2013 F10 550ix
Never owned either but I have Pedal Commander installed on my 550 for 2 years now. 21 settings. No issues and works as advertised. They should all be the same.
      11-04-2018, 04:28 PM   #3
Sunny 528i
Drives: 2012 528i
I've tested the sprint booster v3 and currently have had the BMS Pedal Tuner for a week now. I returned the sprint booster for the fact that it was way too expensive for the same result the BMS pedal tuner does at $100 less, only difference is that the sprint booster v3 had pedal lock and a valet mode. No issues on BMS and it performs exactly like the sprint booster In my opinion.
      11-05-2018, 04:44 AM   #4
sweettalker
Drives: Vrooom
Ur review helped tremendously.
Just what i wanted to hear.
Im glad it worked out for u. I do not need valet or pedal locks so
i will most likely go with bms.
Where did u purchase urs and for how much?
If anyone else has experience please do share.
      11-05-2018, 11:32 AM   #5
535_BiTurbo
Drives: 2012 550I - BMS Stg 1 & CAI
awesome review Sunny528i!!! Thanks
      11-06-2018, 11:45 AM   #6
Sunny 528i
Drives: 2012 528i
Glad to have helped! I bought it directly from burger-tuning for 179.99 + shipping
http://www.burgertuning.com/BMS_PEDAL_TUNER.html
From my previous review:
So I have had the BMS Pedal Tuner in for a week now and man does it make the throttle feel snappy! Getting up to speed is effortless now and it feels like the boost is instant with minimum pedal movement. I tried all 4 levels.
White = stage 1 is stock setting
Green = stage 2 is slightly better than stock
Amber = stage 3 is my current setting and does wonders for daily driving
Red = stage 4 is purely for throttle junkies.
I tried stage 4 setting with the sensitivity set to high for shits and giggles and I almost rear ended someone so please don't try that in traffic. Feels identical to the sprint booster v3 but without the pedal lock and valet settings. For 179.99 it was a no brainer for me.
      11-16-2018, 06:09 PM   #7
aacocella1
aacocella1's Avatar
Drives: E46
If we're talking BMW's i took this guys word
You can get them at the link in the video or they're normally cheaper on sprintboostersales.com
      11-16-2018, 07:21 PM   #8
mike@x-ph.com
Joint Chiefs of Staff
mike@x-ph.com's Avatar
They are identical in how they work, Sprint Booster has more maps but is more expensive
https://x-ph.com/sale/
Phone number 702-494-9435
      11-19-2018, 08:37 PM   #9
strongislemax
Drives: 535
How does pedal tuner work with a flash tune? Is it of value?
I have and mhd stage 1 tune on a 6mt 535. Throttle response is significantly better after the tune.
      11-20-2018, 12:05 PM   #10
SWFLf10
SWFLf10's Avatar
I am also following along to see if it still makes a noticeable difference when combined with a BM3 tune
      11-20-2018, 06:13 PM   #11
sweettalker
Drives: Vrooom
Mine arroved today. I have bm3 ots stage2 tune. Will report back
      11-21-2018, 11:54 PM   #12
Bmw doubles
Dream crusher
Bmw doubles's Avatar
Drives: Fast
2011 535  [0.00]
Concur
IG: @bmwdoubles
      11-26-2018, 11:17 PM   #13
burro_blasta
Drives: 2013 535 M Sport
Just installed bms pedal tune today, I'm mhd stage 1...yep, it makes a difference
      11-27-2018, 09:52 AM   #14
mike@x-ph.com
Awesome
      11-27-2018, 03:31 PM   #15
burro_blasta
Originally Posted by mike@x-ph.com View Post
Awesome
And a big thanks to Mike for the awesome customer service, as always!
      11-27-2018, 05:06 PM   #16
mike@x-ph.com
My pleasure!
      12-03-2018, 09:15 AM   #17
strongislemax
Drives: 535
quick review:
ewg 2014 535 6mt with mhd stage1
The bms pedal tuner definitely makes a difference. One of the reasons I got the MHD tune was to improve throttle response...which it did, but not quite enough. I ended up setting "Sport" mode to throttle only, as a prefer the ride quality of 'comfort" for NYC.
BMS pedal tuner makes a useful difference by being able to fine tune the throttle, separate from the suspension. I set it to stage 1 + 2 step increase. Normal driving and particularly downshifting is more direct. Tip-in is far better, which i thought was weak in sport mode before the pedal tuner, however I am inadvertently slipping the clutch a lot. Installation takes about 5min for anyone with a Torx30 bit.
i understand that there is a kick-down switch for auto cars. the throttle of 6mt does not have this. I am curious as to what difference this makes, and if there should be two different versions for 6mt/auto.
      12-03-2018, 10:40 AM   #18
burro_blasta
quick review:
Similar impressions (also MHD stage 1)...also noticed it helps makes Comfort mode just a bit more aggressive and I end up moving into Sport mode a little less often.
I also keep mine in stage 1 (green)...stage 2 and 3 are fun for giggles but not practical for day to day, traffic or not. Maybe I'll get spoiled some day and start using it on a low stage 2 setting but doubt it.
Installation is super easy if you know what you're doing...for first timers, I recommend having a basic pair of pliers on hand to (very gently) use on the stock plug if you're having a hard time removing it from the pedal. Also, BMS has installation videos on their product page including instructions on how to calibrate, and if you don't calibrate you'll get drivetrain malfunction etc. so it's a must.
I have an auto car but don't see any kick down switch, and honestly don't even know what that is?
      12-04-2018, 03:45 PM   #19
ThaiBruin
ThaiBruin's Avatar
Drives: F10 535i M-Sport
Anyone have a Racechip XLR? I bought it about 2 months ago, but never got around to installing it. I will someday soon, but just curious if anyone else has used it or compared it to the others.
Retired- 2013 MG 328i Sport Line 6MT - BMS Stage 1 / M Performance exhaust / M Performance steering wheel / M Performance shift knob/boot
      07-03-2019, 11:54 PM   #20
jonobro
Drives: bmw f10 535i
they are identical in how they work, sprint booster has more maps but is more expensive
you get what you pay for
      07-08-2019, 02:25 PM   #21
mike@x-ph.com
Should be very similar to sprintbooster or pedal tuner
      07-08-2019, 05:20 PM   #22
jonobro
Sprint Booster is the best don't get anything else brotha
