2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums Regional Forums UK Anyone successfully coded F10 in the UK?
      10-02-2017, 06:20 AM   #507
Tony_ca1
Tony_ca1's Avatar
Drives: BMW F10 LCI
Can anyone confirm that this regen_schliessen works on an F10 ?? I code this last week on my F10 from 2016 and yesterday i had my rooftop tilted up when it started to rain . I then activated the automatic rainsensor but the rooftop did not close, even tried to open the roof top completly and nothing happend. Did i do something wrong or is there another thing i have to code for this to work ?
Thank you
      10-03-2017, 06:36 PM   #508
silo24
Drives: F10 LCI 535d
Originally Posted by JLR1969 View Post
Do you have the modules and steps etc?
From one of the F10 cheat sheets kicking around:
Enable key fob and driver side door handle to fold mirrors and close windows and moon roof:
CAS => 3003 => KOMFORTSCHLIESSUNG_FB => aktiv
CAS => 3003 => KOMFORTSCHLIESSUNG_PA => aktiv
FRM => 3020 => ASP_BEIKLAPPEN_BEI_KOMFORTSCHLIESSEN => aktiv
To change mirror fold delay
CAS -> 3003 -> KMFRT_SCHLIESSEN => Werte= 05 for 0.5 sec, 0A for 1 sec, 0F for 1.5 sec
F10 LCI 535d (313PS) M Sport
JLR19691882.00
      10-04-2017, 08:37 AM   #509
Tony_ca1
Tony_ca1's Avatar
Drives: BMW F10 LCI
I am looking if there is a way to get the side mirrows to start heating when i push the defrost button for the rear window. My F10 sleeps outside and last week there was allot of fogg in the morning and i could not see anyting true the side mirrows . After 10 min my rear window was clean but the side mirrows where not. I cant believe that such a premium car cant heat the mirrows witouth the temperature beiing below 5C celcius. I fount this entry but dont know what it means.
Thank you
      10-06-2017, 08:12 AM   #510
NickCW
Drives: BMW 530d
Hi all,
My car has folding mirrors (you press a button inside the car) which I would like to add to car locking/unlocking - is there anyone who can do this local to me? (Milton Keynes way).
Also it seems some are able to use the remote fob to do this, what is the sequence as I believe mine just opens/closes the windows..
      10-06-2017, 03:13 PM   #511
JLR1969
Drives: Kubota GR1600
Originally Posted by NickCW View Post
Hi all,
You should just hold down the lock button for a few seconds and it locks folds etc
      10-08-2017, 12:27 PM   #512
JLR1969
Originally Posted by silo24 View Post
Only way to do this is to change the delay time on the comfort close function.
Basically when you hold the lock button, it usually takes a couple of seconds to start folding, but the delay can be programmed. I have mine set to around 0.5 seconds.
Changed this to 0.0 seconds so it closes as soon as its locked, so much better than factory.
Also changed the angle of wing mirror dip and can auto fold at 40mph when driving down country lanes.
Video in motion is also working and lots of other improvements
      10-09-2017, 03:39 AM   #513
JLR1969
Does anyone know if its possible to code the Fog Lights to come on with the high Beams?
      10-09-2017, 03:59 AM   #514
NickCW
Drives: BMW 530d
Thanks I will have to try that, I didn't realise it would work on lock.
Does that mean you can open them when you unlock? I presume if you hold unlock it will global open the windows...
      10-09-2017, 04:21 AM   #515
JLR1969
Not sure about opening windows on unlock
I have just coded the car so it folds mirrors on lock.
      10-09-2017, 07:05 AM   #516
gspannu
Drives: F10 535, F82 M4
Originally Posted by Tony_ca1 View Post
gspannu here is my CAFD file i only find 1 SM module
Here is a link to my CAFD file
https://mega.nz/#!qVhEXDSI!I3wNj-0sP...1WanKgFISbtQXE
the key
!I3wNj-0sP8Knd0Jc0Lso1hFH7tt3N1WanKgFISbtQXE
The passenger module is in another CAFD file. Something like SM6e
Send a screenshot of E-Sys. after you have connected, read all ECUs, filter by CAFD.
      10-09-2017, 07:08 AM   #517
gspannu
I believe it was possible in some early variants of F10. I may have the code somewhere, will try and dig it up.
However, I presume you are aware that it is not road legal to have fogs on all the time. Is it really worth the risk, rather than having to press a button - when needed.
JLR19691882.00
      10-09-2017, 07:11 AM   #518
gspannu
I wouldn't set this to 0 seconds, maybe something like 0.2.
You run a small risk of damaging your folding mirror motors.
Assume super cold conditions, mirror mechanism is almost frozen. You lock your car, and the mirror try to close; and you end up damaging your motors or plastics being broken.
My suggestion is to have a little more control. The difference between 0 and 0.2 is negligible, but will give you the ability to not close if not needed.
JLR19691882.00
      10-09-2017, 07:13 AM   #519
gspannu
Yes, it works on opening windows & sunroof as well.
      10-12-2017, 03:14 AM   #520
NickCW
Drives: BMW 530d
Quick update, it turns out if you lock the car and then hold to fold the mirrors then the car will automatically unfold them when you unlock, with just a single short press.
So you don't have to hold and activate the global opening.
      10-14-2017, 04:35 PM   #521
Tony_ca1
Tony_ca1's Avatar
Drives: BMW F10 LCI
I found out that if you just have the normal seat ,heated , and electric powerd you just have one SM(d) modele only when you have the comfort seat then you have the both modules. I have read all the ECUs and there is only 1 SM module.
Thank you.
      10-15-2017, 03:38 PM   #522
gspannu
Thank you.
Yes. You are right. I had (mistakenly) assumed that you had the comfort seats.
      10-16-2017, 06:41 AM   #523
xenon
xenon's Avatar
England
1405
Drives: 2021 G21 330i M-Sport
Why on earth would you want to do that?
Ian
Current: 2021 G21 330i M-Sport
Previous: 2018 A6 Avant S-Line MMI+, 2014 F31 320d M-Sport, 2013 F10 520d M-Sport, 2011 F10 530d M-Sport, 2008 320i M-Sport Coupe, 2002 325i, 2001 318i valvetronic, 1998 318i, 1996 525i, 1990 Porsche 944S2
      10-16-2017, 07:00 AM   #524
JLR1969
Better illumination on country lanes.
      10-16-2017, 07:08 AM   #525
xenon
xenon's Avatar
England
1405
With bi-xenon headlamps on full beam you wouldn't even notice the fogs being switched on. If I had my way, fogs would be illegal anyway - hateful things.
Ian
JLR19691882.00
      10-16-2017, 08:12 AM   #526
JLR1969
Have just coded the HK sound to Bang & Olufsen
The sound stage is improved and the quality is better
It's never going to match the actual quality of the system with the correct speakers and amps but it is better
      10-16-2017, 10:19 AM   #527
gspannu
Could you try these settings and let us know if the overall quality improves...
B&O Expanded: Off
Fader +2
Treble +4
Bass 0 (or +1)
100Hz -2
200Hz -1
500Hz 0
1KHz +2
2KHz -3
5KHz +4
10KHz +6
      10-16-2017, 11:36 AM   #528
JLR1969
B&O Expanded: Off
Fader +2
Treble +4
Bass 0 (or +1)
100Hz -2
200Hz -1
500Hz 0
1KHz +2
2KHz -3
5KHz +4
10KHz +6
Sure will do it later
