2010 2011 BMW 5 Series Forum F10 Compiling some F10 535 sway bar info |
10-29-2020, 04:44 PM | #23 | |
Rep 441
2013 535xi M Sport (PWG) // PS2 // Spool fx150 // MHD // xHP // FTP Inlet // FBO: AR HF DP, Wagner IC, BMS Intake, VRSF CP
10-29-2020, 05:35 PM | #24 |
Rep 1,445
Drives: F10 S55, E93 M3, E89 N54
yea, end links don't need to be under load when tightened, jack that thing up! and just go tight, no torque to spec needed but 20 ft lbs seems a little light to me.
01-04-2021, 02:07 AM | #25 | |
Rep 41
Im in Chocago area as well. I looked on KW site and they dont have a system for 535, just one that comes with hydraulic lift. I also not want to lower the car. How bad was the M5/650 sway bar upgrade? my car is DD and mostly driven by my wife, i dont care to make it perfect track car, just a little less of a boat around the corners. Any info would greatly help
F10 535I xD, 957 GTS, 991.1 C2 MT
F30 328i xD, 2006 Carrera 4, 2007 S550, 2006 CLS500, 2004 S500, 2004 CLK500, 1999 Lexus GS300, 2001 C320, 2002 C230K Coupe 1998 VTR - 1000, 1986 GSX-R 750 |
01-04-2021, 10:41 AM | #26 |
Rep 235
"How bad was the M5/650 sway bar upgrade? my car is DD and mostly driven by my wife, i dont care to make it perfect track car, just a little less of a boat around the corners."
I thought it was still way too hard for Chicago's crappy pavement, hence my purchase of the V3 system. I doubt your wife will like the M5 option. Consider upgrading the shocks instead. With the V3 setup, my car corners like a skate board. No roll whatsoever and the ride is actually softer than the oem setup. Good luck. |
01-06-2021, 10:34 AM | #27 | |
Rep 4,633
Do you use any lube for the rear bushings? Bmw sells a specific lube for the install of those bushings into the bracket
Current: E63S AMG 4matic RENNtech || M5 Evolve..Eventuri || F10 LCI 535i MHD
01-06-2021, 11:11 AM | #28 | ||
Rep 441
