2010 2011 BMW 5 Series Forum F10 bushings for front sway bar - 2011 F10 528i N52 engine |
06-15-2022, 09:13 AM | #1 |
Rep 168
Hi all,
Does anybody know any other places to get just the rubber bushings for front sway bar? 2011 F10 528i N52 engine (6 cylinder) all the places including FCPEuro sell sway bar with bushings attached part number (31356777933). So you gotta buy and replace sway bar which i try to avoid. Based on https://www.realoem.com/bmw/enUS/sho...diagId=31_0827 diagram (see attached), rubber bushings do not have separate part number and come attached to the sway bar. i was able the find this site which sells them but then again may be there is reason on why bushings are not sourced a separate parts based on bmw ? https://www.powerflexusa.com/shop/pr...4401#attr=2492 Last edited by OrcaPod; 06-15-2022 at 09:30 AM.. |
06-15-2022, 09:42 AM | #2 |
Rep 598
You should have the 13mm bar which requires this bushing
https://www.fcpeuro.com/products/bmw...mm-33556788861 |
OrcaPod73.50 |
06-15-2022, 10:41 AM | #3 | |
Rep 168
based on the diagram . are they compatible with FRONT as well? |
06-15-2022, 01:50 PM | #5 |
Rep 168
Sorry moderators. I guess i posted my thread in a wrong subforum. Should have posted it under " Wheels / Tires / Suspension / Brakes"
Please move if needed |
06-15-2022, 03:18 PM | #7 |
Rep 168
06-16-2022, 12:18 PM | #8 | |
Rep 34
Use an open-ended wrench or caliper to get the diameter and see what is available in that size. It may take some trial and error but is certain to be less expensive than replacing the assembly. |
OrcaPod73.50 |
06-16-2022, 03:46 PM | #9 |
Rep 2,588
The front bushings are bonded to the sway bar for whatever fucking reason, and the only way to get new ones from BMW is to buy a new sway bar.
2015 BMW 535xi
Bootmod3 Stage 2 | ER charge pipe | ER Catted DP | Remus Exhaust | Gplus FMIC | KW V3 | Turner Monoball thrust arm bushings | Wallet regrets ISTA VM Setup/Tutorial Last edited by Unspec; 06-19-2022 at 02:04 PM.. |
OrcaPod73.50 |
Tags |
bushing, f10 2011 528i, sway bar |
