2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications Jerky 6-5 downshift
      08-31-2019, 09:43 AM   #1
max_k
Drives: 330XiA 2006
Jerky 6-5 downshift
Hi!
I suddenly got a real jerky downshift when shifting from 6-5.
I drove around for a while and hope for it to get better, it dit. But it’s still there.
I’ve looked at my adaptation values and could see that the B solenoid had 120ms fill time while the other got around -1 to 7ms. And yeah, that could matter because the B solenoid is active in gears 1-5.
And when i shift to 6th gear it was kinda slow, i felt the car slow down a little bit when 6th gear was engaged.
So i managed to change the oil and filter in my tranny. I took down the valve body and replaced the B solenoid as well. The oil was really bad, and i managed to get out about 7ltr so that was good!
After the change it got a little better. But it is very harsch when i do a kickdown from 8-5gear or any gear above 6th to 5 or less.
So the delay seems to be there yet.. When i Coast down to standstill the blue gauge for efficient dynamics goes away for a little bit. It is like is lost the gear for a little time and kicks in the new gear.
Now my B solenoid is in 36ms, so its better, but not good..
Am i looking for a new valve body?
The fault doesn’t feel mechanical at all. It is just that it doesn’t know how to shift anymore
It can do soft downshift when i coast in 6th gear and let it go down to like 1000rpm then give a little more throttle before it shifts down. Then i shift smooth.
The car is s 530xd 2012 with zf8hp70
And again, the fault came suddenly one day i were drivning.
      09-12-2019, 07:12 PM   #2
Morebs4me
Drives: 550i
Did you reset adaptations?
      09-12-2019, 08:54 PM   #3
Bmw doubles
Dream crusher
Bmw doubles's Avatar
Drives: Fast
2011 535  [0.00]
Maybe unrelated but next step is replacing my transmission mounts with stiffer versions. You know when the trans moves you lose power and it feels jerky.
IG: @bmwdoubles
      09-16-2019, 03:10 PM   #4
max_k
Drives: 330XiA 2006
Yes. And now im back at about 120ms on my B-solenoid
      09-16-2019, 03:15 PM   #5
max_k
Drives: 330XiA 2006
I dont think its the mounts, because my fill time is way above the limits for my B-solenoid. And the b-solenoid is active between 1st to 5th gear. Any downshift from 6th or higher to 5th or lower i can feel the jerk.
But when i’ve done a jerky downshift, and i let it shift up and then do it again it feels much smoother. But if i Cruise in like 8th gear for a while and do a kickdown its there again.
      10-06-2019, 12:33 PM   #6
mashpotato
Drives: '11 F10 N55
Parts are probably worn out. New valve body?
or rebuild https://www.sonnax.com/parts/4590-zip-kit
There are videos around on valve body rebuilds. If you go down that route you can use it as reference.
