2010 2011 BMW 5 Series Forum F10 INA Belt tensioner new replace failed? |
05-21-2019, 04:11 PM | #1 |
Rep 915
Just replaced old belt tensioner due to rattle. Just had INA tensioner installed for maybe a month and it has same rattle as old one. Is there a reason it would fail so quickly? Video Attached 3 second clip.
I have life time warranty with FCPeuro also. Update: Tensioner is fine, idler pulleys suspected bad, will be ordering new ones soon.
Instgram @burninja
05-22-2019, 07:16 AM | #3 | |
Rep 1,873
If it's the noise - pull your oil filler cap and you might find the rattle you thought was the tensioner or pulley is actually the vacuum pump under the valve cover. I did - and ordered belt parts it turns out I didn't need. I also crapped my pants when I heard the racket from under the valve cover until I learned it was normal, including a bit of a squeaky property in the sound until it's mostly warmed up. If the movement is keeping you up at night, *some* movement is normal. The tension arm is supposed to deflect to maintain constant tension and that might mean movement. Especially if you're just starting up cold and the belt has been sitting stationary on the pulleys and cooled into a certain shape. |
BurrNinja430.50 |
05-22-2019, 07:26 AM | #4 |
Rep 915
Not keeping me up just a concern with rattle since all my parts are warrantied. I just needed a second opinion which I appreciate all the help! Also is that a typical noise of the vacuum pump?
Instgram @burninja
04-12-2021, 12:01 AM | #6 |
Rep 915
Yeah I've come to learn slight vibration is normal, the ticking may also be the vacuum pump. Havent had any issues just a lot of learning being done on my end.
Instgram @burninja
04-12-2021, 07:32 AM | #7 |
Rep 658
I had a nasty metallic tapping noise once the engine was warmed up that would start a touch off idle (around 900rpm). My AFR was all over the place between mid-13s to high 15s. I was scared it was my HPFP.
So I grabbed my mechanic's stethoscope and started poking around with a buddy holding the gas at the rpm the noise started. Low-n-behold, my 1.5yo INA belt tensioner (got it through ECS) was screwed up. Pulley's bearing was fine, but the tension mechanism was fubbar'd causing all kinds of clickitty-clacks. Replaced it with an actual BMW tensioner, and not all is well in the world. Moral of the story- a cheap and simple mechanic's stethoscope saved me a ton of expensive work . I highly suggest you use one and really pin down the source of your noise. The tensioner's movement is within normal spec. So you just have to verify that the noise is in fact from there
11' M-sport- 371WHP - 478WTQ on stock PWG E50 TunedbyShoup // 386WHP - 429WTQ on Shuenk N55+ with ultra-conservative 91 Octane tune // Starting full-range flexfuel tuning in Spring '24 |
08-10-2021, 01:13 PM | #8 |
Rep 716
I'm in the process of replacing my belt, belt tensioner and idler pulley… just curious if I should just get genuine Bmw or go with INA… I am asking because there are mix reviews on it… any feedback welcome… thank you
08-10-2021, 04:40 PM | #9 |
Rep 915
Mine is so far good. Havent had an issue, come to conclusion it is supposed to have some slack in it just not major movement.
Instgram @burninja
ey2001310.00 |
08-10-2021, 10:18 PM | #10 |
Rep 1,442
Drives: 2011 535i 6MT
Mine has been a-ok so far. I guess it comes down to would it be worth it to re-do the job if you had to get it replaced under warranty?
08-11-2021, 02:09 AM | #11 | |
Rep 716
08-11-2021, 03:55 AM | #12 |
Rep 1,873
INA is OE, by my recollection. It's the same thing.
