2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes 535i ---> 550i front brake retrofit
      03-18-2018, 09:48 AM   #1
Stück
Stück's Avatar
Drives: F10 M5
1991 318iS  [0.00]
2014 M5  [5.00]
2013 X3 35i  [0.00]
Since having considerably upgraded my 535i's performance with a Pure Stage 2 turbo, Mission Performance Stage 3 flash tune, and all of the other "full bolt on" supporting mods you's expect I found myself overwhelming the front brakes factory spec'd regularly.
Just a few highway pulls following by briskly dropping anchor would leave the front end shaking so violently under braking I'd often elect to just not brake
Obviously this needed some attention. I considered doing the OE M5 front brake upgrade but I felt people were just asking too much for the used calipers. The rotors were pretty expensive too, but that I don't mind so much. I also considered Stoptechs kit for our cars but again its just mega expensive and at the end of the day this is really just a daily driver.
I do need it to slow the hell down once in a while though
I elected to retofit the front brakes from a 550i onto the car. Everything is direct bolt on with no modifications needed.
I purchased a pair of brake new brake discs, which have directional cooling vanes. 535i discs are NON directional.
Looking at the picture you're going to to think these rotors are "the same size" and you wouldn't be wrong, but you wouldn't be right either. What BMW did was keep the rotor at 348mm diameter, but reduce the size of the aluminum bell to allow the friction surface to move inward. They also added to the disc's width, 36mm wide vs 30mm wide on the 535i.
The calipers are also very similar at a casual glance, but the 550i unit again is larger, wider and reaches further inward to clamp a brake pad that is ~35% larger in surface area than the 535i pad. I somehow lost or deleted the pad comparison picture, sorry.
The calipers both utilize the same 60mm size piston so no hydraulic changes are needed.
The brake dust backing plate does not require any adjustment, and the original brake hose worked as well. The calipers were donated by a wrecked 7500mi '15 550i that met its demise.
Overall braking torque is noticeably increased, and with the Michelin P4S rubber I run the car drops anchor at a moments notice. I've had this setup about 2 months now and have been quite pleased with the cost effective upgrade.
      03-18-2018, 10:57 AM   #2
.BMW.
.BMW.'s Avatar
Sweden
1811
Drives: BMW F11/F31
Great info Stück!
      03-18-2018, 07:32 PM   #3
Stück
Stück's Avatar
Drives: F10 M5
1991 318iS  [0.00]
2014 M5  [5.00]
2013 X3 35i  [0.00]
Just after a much needed wash, you can see how close the further inboard caliper is to my concave BC's
      03-18-2018, 07:59 PM   #4
remmib
remmib's Avatar
Norway
1321
Drives: 2013 F10 520d M-Sport
Bigger brakes always look cool.
      03-18-2018, 08:50 PM   #5
Proimport
Drives: 2014 BMW 535i
Nice write up thanks for the info I might have to do that to my 535i.
      03-18-2018, 09:45 PM   #6
Drives: 2014 535i M Sport
I assume the stock M Sport wheels will clear the calipers...
      03-19-2018, 07:37 AM   #7
lsturbointeg
lsturbointeg's Avatar
Drives: 2011 535i Jet Black
      03-19-2018, 07:55 AM   #8
Surly73
Any concerns with altering the Front/Rear bias of the car? Does the 550 have a different bias valve than the 535, or does it count on being more nose heavy to balance things out?
      03-20-2018, 07:01 AM   #9
thakid22
Drives: 2015 BMW F10 535i M-Sport
Exclamation
Umm... Isn’t that tire mounted inside out/backwards? Gotta watch those tire shops... Looks like that tire needs to be mounted the other way on that rim.
      03-20-2018, 09:27 AM   #10
ey2001
ey2001's Avatar
285
Drives: F10 535i 6spd
Wow good eye
      03-20-2018, 02:16 PM   #11
Stück
Stück's Avatar
Drives: F10 M5
1991 318iS  [0.00]
2014 M5  [5.00]
2013 X3 35i  [0.00]
Indeed it is lol, I'm aware of the issue I'm just too busy to go by Discount and have them fix their shit.
      03-20-2018, 04:06 PM   #12
thakid22
Glad you you know about it. Carry on!
      03-20-2018, 04:13 PM   #13
thakid22
Originally Posted by ey2001 View Post
Wow good eye
Lol. Thanks!
      05-12-2018, 06:36 AM   #14
.BMW.
.BMW.'s Avatar
Sweden
1811
Drives: BMW F11/F31
I did this aswell yesterday, but the Euro spec version of 535 and 550 brakes. Which means I went from 348x36 rotors to 374x36, both directional 2-piece rotors.
Details and part numbers in this thread: f10.5post.com
Visual comparision of the rotor sizes.
      05-12-2018, 07:21 PM   #15
f10_will
f10_will's Avatar
Drives: F10 535 msport xdrive
I retrofitted f10 m5 brakes on my 535 xdrive
      07-11-2020, 07:06 PM   #16
Tevzadze2.0
Drives: 2011 Bmw 535 xi
Which caliper is the 550 caliper , the one that reads 60/30? On the right . Didn't catch that part
      07-15-2020, 09:19 PM   #17
BrowBMW
BrowBMW's Avatar
Drives: 2011 535i 6MT
DUDE! I wonder if this is what happened to me... look at my fiasco with my brakes and how I had to grind my calipers and pads down to fit onto the larger sized center hub. I bet I had 550 DISCS! Can you check out my thread @stück?
2011 535i 6MT Currently: MHD stage 2+ flash on 95 running e30, BMS Intake, BMS Charge pipe, high flow sport oil cooler value, billet oil thermostat cover and oil filter cap, CDV Delete, Armytrix CLDP and full exhaust, Short throw clutch stop, Wagner Knockoff FMIC, H&R f&r sways, BC modified COs by Redshift, Strut tower bar, Spherical endlinks, ESC SS Brake lines, Cross drilled/slotted rotors w/ceramic pads - Check out videos here
      07-15-2020, 09:24 PM   #18
BrowBMW
BrowBMW's Avatar
Link for reference... https://f10.5post.com/forums/showthread.php?t=1726542
      07-16-2020, 12:04 AM   #19
Unspec
Unspec's Avatar
Drives: 2015 BMW 535xi
Discs? You mean calipers right? You commented on your thread that you seemed to have 7 series calipers. The 550 and the 7 series share the same calipers in the US, so you would be right.
If you had the larger 60/36 calipers, then ordered the 535 rotors with the larger hub, makes sense that it rubs. It looks like you already had the full 550 brakes and kinda undid the mod.
2015 BMW 535xi
Bootmod3 Stage 2 | ER Catted DP | Remus Exhaust | Gplus FMIC
Copyright ©2000 - 2020, vBulletin Solutions Inc.
