2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications F10 - N63,N63TU intake system
      03-09-2015, 11:34 PM   #89
Simple5
Drives: F90 M5 and E84 X1 Xdrive35i
On the stock air filters which way does air flow into the engine? Top to bottom of bottom to top?
      03-10-2015, 01:01 AM   #90
badblack550xi
badblack550xi's Avatar
bottom to top
2011 550i RWD 60-130 7.35
      03-12-2015, 06:26 PM   #91
Downfourit
Drives: M6 Gran Coupe`
How's things going, any new updates?
      03-12-2015, 07:00 PM   #92
gclions
gclions's Avatar
78
Drives: 2011 550i
I'm still waiting on elbows from the machine shop, he's been backed up from the unusually large amount of snow.
I have all other tubing/reducers/filters in hand. I'll install and drive it long enough to adapt, then it will be dyno/track time.
      03-12-2015, 10:52 PM   #93
Simple5
Is your intake different than the one that badblack is showing?
      03-13-2015, 06:13 AM   #94
gclions
gclions's Avatar
78
Drives: 2011 550i
Same setup, we've worked together to try and get this done right this time. He can speak for himself, but both of us getting machined components back is what is limiting progress. I received the last part I needed (besides elbows) yesterday. So we're getting close to installation and testing.
No butt dynos will be used, as I'll use the same dyno I used before. Plus, I found a pretty good 1/8th mile track within 45 min of me. After all that we should have a pretty good idea of what we're working with. BB is working the same thing in parallel.
      03-13-2015, 07:37 AM   #95
badblack550xi
what he said ....we are both working on same prototype and are waiting on machine shops.
      03-15-2015, 12:15 PM   #96
gclions
gclions's Avatar
78
Drives: 2011 550i
Installation complete. Testing in progress. Adaptations are going to require patience on my part.
So far so good.
      03-15-2015, 01:12 PM   #97
ARC550
Drives: M3, X5, 720s, X5, 750xi
So far so good.
If your looking for a ry fast TU car to test it.. I'm your guy!!
      03-15-2015, 06:39 PM   #98
Simple5
So the one you originally posted is a bust?
      03-15-2015, 07:14 PM   #99
ARC550
No, not at all. I want to test this one also. Lol I'm a trial and error type of guy. Whatever gives best gains is the one I keep! Lol
I'm a slut!!
      03-15-2015, 07:23 PM   #100
gclions
gclions's Avatar
78
Drives: 2011 550i
Well, I broke a vacuum line. Tried to chase a phantom vacuum leak, lost a small piece of rubber via the PCV. So, I'm waiting for the car to crap it out the backend.
So, it was a crappy day. Back to stock until I can buy new vacuum lines.
I did successfully install and drive an F10 550i with a cold air intake before I started breaking stuff. Sounded great by the way.
I'm going to leave it up to BB for now, he's got the same setup in the works. This is promising, just needs some careful adjustment, which apparently isn't in my skill set.
      03-15-2015, 08:39 PM   #101
badblack550xi
I'm a slut!!
You're such a whore!
      03-16-2015, 09:08 PM   #102
gclions
gclions's Avatar
78
Drives: 2011 550i
Well, BB and I managed to think through potential problems. I think we came up with a solution. So elbows go back to the machine shop tomorrow.
It doesn't hurt that my wife found the rubber plug I thought my car ingested sitting in the driveway. So game on again!
      03-16-2015, 11:17 PM   #103
badblack550xi
Fingers Crossed!
      03-22-2015, 05:12 PM   #104
Downfourit
Originally Posted by badblack550xi View Post
Fingers Crossed!
Same here!! I just want to get an intake on this beast already!
      03-22-2015, 05:19 PM   #105
gclions
gclions's Avatar
78
Drives: 2011 550i
I'm close (that's what she said), and I've already proven it will fit (that's what I said). I drove it, but had some issues with the MAF flange height. Dropped the elbows off with the machine shop to get the flanges cut down on Friday. I expect them back by mid-week, install this weekend to see if it solved my misfire problems.
The only thing I can come up with is the larger tubing doesn't sit up in the flange as much, so though it may have worked previously, the heating strip that the MAF uses to meter air was partially obscured, and that led to multiple MAF errors/misfires. I could keep the car running, but it hated me. I'm confident it's close to a working prototype now, and the changes will allow the car to adapt. After that we'll know if this is possible.
I start shift work this next week, working day shift, so install will likely need to wait until the weekend even if I get the elbows back mid week.
2011 BMW 550 i / Sophisto Grey / BMS Stage 2
      03-27-2015, 12:30 AM   #106
ARC550
And then....
      03-27-2015, 12:40 AM   #107
Simple5
And then....
What's going on with yours bro?
      03-27-2015, 09:04 AM   #108
badblack550xi
Summer is here those cones under hood will just suck some of that nice HOT AIR.
      03-27-2015, 11:00 AM   #109
Simple5
Man... you two love busting each other's balls huh? LoL
      03-27-2015, 11:44 AM   #110
badblack550xi
His car is basically mine considering the amount of work i did on it
