09-29-2019, 10:44 PM | #23 |
Rep 1,442
Drives: 2011 535i 6MT
Pretty sure you need catless dp for burbles, I have no tune with catless and I get them from time to time already.
09-29-2019, 11:09 PM | #24 | |
Rep 688
https://f30.bimmerpost.com/forums/sh....php?t=1579442 It looks like you can get burbles with stock dp, but it can potentially damage the dp and cause emission test issues if you're too aggressive with it. It looks like I'll need to play with the BM3 settings to get some occasional/mild burbles.
Retired- 2013 MG 328i Sport Line 6MT - BMS Stage 1 / M Performance exhaust / M Performance steering wheel / M Performance shift knob/boot |
09-30-2019, 08:52 AM | #25 | |
Rep 2,590
My maps -> click on your tune -> top right cog (Config) -> Exhaust burble type "Custom". Adjust to your hearts content. Do note that the bootmod3 website is also designed for touch screen use (why??) so in order to scroll up and down, you need to click and drag as if you're using your finger. Took me a while to figure that one out. As for damaging your cat, just don't make it super aggressive and you'll be fine. I'm on stock DP and I get burbles just fine, though I do have a Remus axleback but not sure if that'll make a huge difference compared to MPPK A proper flash tune is going to be night and day compared to a JB4 or other piggyback tune. |
09-30-2019, 10:02 AM | #26 | ||
Rep 688
and fully agree, this tune is a MUST considering how easy it is to perform and how much Pro Tuning Freaks are constantly updating their maps.
10-01-2019, 09:13 AM | #27 | |
Rep 2,590
I've attached a screenshot of my personal settings. I'm not sure how safe or unsafe it is, it is just what I use. Use at your own risk lol Edit: Attached photo of transmission tune location Last edited by Unspec; 10-10-2019 at 11:07 PM.. |
10-02-2019, 03:11 PM | #28 | |
Rep 688
10-02-2019, 06:00 PM | #29 |
Rep 75
Fill up with E30 and flash the E30 tune, huge difference! I haven't put my DP on yet because the car needs to go in for maintenance. E30 is a sweet tune!
10-02-2019, 06:14 PM | #30 | |
Rep 2,590
10-10-2019, 11:58 AM | #31 |
Rep 182
10-12-2019, 04:36 AM | #33 |
Rep 32
does The bm3 adjust is your e30 blend is off a bit? Also, does the bm3 adjust if your supporting mods aren’t sufficient enough for the tune you are running?
10-12-2019, 09:54 PM | #34 |
Rep 1,299
They are static maps... And description tells you what you need to have mods wise in order.to run that map. E30 map requires E30 but you can probably have e40 and be fine but lower than E30 might be an issue with timing.
10-14-2019, 09:09 AM | #35 | |
Rep 2,590
If you don't have the suggested mods listed, you can run the map still. Just expect something to break quickly. |
10-14-2019, 10:13 AM | #36 |
Rep 1,442
JB4 map 5 has an auto-tune option... but then it's a piggyback tune vs a true flash.
10-19-2019, 09:54 AM | #38 |
Rep 85
Tune done yesterday. Car feels amazing. Super responsive and pulls ridiculously hard. Power band is smooth and much improved. Very happy so far and customer service was phenomenal. I highly recommend. I need to find my go pro and will take some videos. Once I get my bolt ons I will have reflashed and dyno'd.
10-21-2019, 07:49 AM | #39 |
Rep 75
10-21-2019, 01:26 PM | #40 | |
Rep 182
