2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Navigation, iDrive, Audio, Video, Bluetooth, Phone, Coding Change Head Unit to NBT in 2013 535i
      02-06-2019, 11:51 PM   #1
_GW_
Drives: F10 535i xDrive
I'm preparing to change my head unit to a NBT unit that I purchased from eBay. This NBT unit should allow me to code a iDrive resolution output that is higher than what my original radio was sending to my original 6.5 inch screen. I already replaced the 6.5 inch screen with a 10.25 inch Android screen. The tablet side of the Android screen looks great with its higher resolution but the iDrive side of the Android screen still receives a lower resolution from iDrive.
I'm looking over this head unit before I open up my dash to install it. It appears to offer more connectors on the back than what's available on my original radio.
So far it seems obvious that the BIG PINK connector on the far-left will be for the display. And the little BLUE connector on the far-right is for GPS.
1. Does anyone know the purpose for each of the other connectors?
2. There's a WiFi label on the top of the radio. Does this WiFi feature mean I could connect the radio itself to any WiFi network so that the radio can access the internet?
      02-07-2019, 02:16 AM   #2
wcr3d
Drives: 2013 535i XDrive M Sport
www.newtis.info
You should be able to research some questions there.
You do realize there are different versions of NBT?
I'm not sure I understand what you're trying to do exactly.
_GW_25.00
      02-07-2019, 03:56 AM   #3
lsturbointeg
lsturbointeg's Avatar
Drives: 2011 535i Jet Black
another reason why I never got around to doing mine. it's not just a simple plug and play and boom 10" screen
      02-07-2019, 09:36 AM   #4
_GW_
Okay. Since I already bought the radio and have it, I might as well do some research to try and make it work.
We'll see what happens.
      02-15-2019, 10:59 AM   #5
Xtreemk
Nigeria
Drives: BMW 535i 2012 GCC
iDrive controller Multimedia etc not working
After having a long journey with my 535i. I went out to buy something outside I left my kid in the vehicle. When I came back I realized i can only access radio from the dashboard. The idrive controller is not working. All other functions on the screen are shadowy. Only the radio function works.
No warranty.
Outlaws
      10-09-2019, 05:40 PM   #6
Kingkajee
Drives: BMW F10 520d M Sport
Hey buddy,
Did you get anywhere with this?
My 2015 F10 Lci has the original nav with a 6.5" screen. Using an android screen, I was hoping I could use a Pro head unit with the android screen.
I can only think the idrive controller will be an issue
