2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications F10 535i XDrive Coolant Predicament?
      09-10-2019, 10:34 AM   #1
David_Vasha
David_Vasha's Avatar
Drives: 2011 535i XDrive
Hey everyone. I just bought an f10 535i Xdrive and was checking the coolant fluid level. When I first checked it out it showed me that it was at the minimum level in which I topped it off and filled it up. I drive it for a day or so and I check the level again and it shows me that it's at the minimum level again. I checked for leaks but I can't seem to find any. There are also no warning lights on so should I just leave it alone for should I seek more details out?
      09-10-2019, 12:29 PM   #2
David_Vasha
Anyone have suggestions?
      09-10-2019, 08:38 PM   #3
David_Vasha
Bump. Just tryna see if anyone got something to add or maybe I'm just losing my mind.
      09-10-2019, 09:37 PM   #4
You can try adding dye into the system and then get a blacklight to find the leak. You can also look for white spots in the engine bay.
      09-11-2019, 08:25 AM   #5
Unspec
Unspec's Avatar
1300
Drives: 2015 BMW 535xi
Go to a mechanic, people on the forums can't diagnose your car without seeing it. It's definitely concerning.
      09-11-2019, 08:30 AM   #6
David_Vasha
Should I try the dealership or should I try an independent shop. I've got a good local one with a good rep in my town
      09-11-2019, 09:12 AM   #7
Unspec
Unspec's Avatar
1300
Go to whichever is cheaper. Have them figure out what's wrong first, and then shop around for repair options.
      10-08-2019, 08:41 PM   #8
Brian Edward
Drives: 2013 528i twin turbo sedan
Have a similar kinda deal
My 528i seems to spit it out of the overflow tank, cause you can see dried spray there and the front of the car while running always smells like coolant. Small problem, coolant tank cap may need replacing.
      10-09-2019, 01:10 PM   #9
jooobi3
jooobi3's Avatar
Drives: 2011 BMW 535i XDrive
If I'm not mistaking the coolant is getting through the system. You want to have the car running and open up the cap and continue to add coolant. The coolant level will keep dropping if there's not enough coolant circulating in the system. I did this with my sport bike.
