2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications Xhd trans tune?
      02-08-2019, 03:33 PM   #67
Sylverlee
Drives: White 535i M-Sport, 911 GTS
Anyone run the XHP with a piggy back tune?
      02-08-2019, 04:31 PM   #68
ziekxq
Drives: 2011 535i xDrive
Got it with JB4 and I will be yanking JB4 out.
      02-08-2019, 05:07 PM   #69
Sylverlee
Does it just shift slower? Guess xhp> jb4 then. That’s good to know! Thx
      02-08-2019, 06:09 PM   #70
ziekxq
Nope, it shifts fine, just that manual shift is so fast that JB4 cant handle it. I havent done the ISO mod on this box. I plan on selling it to get proper flash tune done.
      02-09-2019, 12:06 PM   #71
Surly73
xHP, xDelete and either BM3 or MHD are on my spring wishlist, I think
      02-10-2019, 06:32 PM   #72
SC300T
Drives: 13 E92 M3, 540xi, 535ix GT
When cruising in D, does it still climb into 8th gear at 40-45 mph with the flash? Can't stand that it turns 1200rpm at 45mph. There is no sport in that. When stock, if you switch it to sport, its in 5th gear at 45 or comfort 8th gear at 45, there is no in-between. Seems like 45mph should be 6th or 7th when cruising.
      02-10-2019, 08:47 PM   #73
jonobro
Drives: bmw f10 535i
Whats xdelete?
      02-10-2019, 08:49 PM   #74
ziekxq
Originally Posted by jonobro View Post
Whats xdelete?
It makes xDrive into RWD using software tuning. You have to flash each time you want either version of drivability.
      02-11-2019, 12:01 PM   #75
AZ_Bmw_550
Drives: 2015 BMW 650i GC
2011 BMW 550i  [0.00]
Does anyone know if this is compatible with the N63TU cars? I tried emailing them and no response...
      02-11-2019, 01:29 PM   #76
WaqasRiyami
Oman
46
Drives: BMW F10 ( 535i )
not yet
2011 F10 535i N55 PWG 8AT | "Pureboost.de Tune" + MHD Flasher | xHP Stage 3 Transmission Tune | N20 3.5bar TMAP Sensor | Pure Stage 2 Turbo | GFB DV+ | Fuel-It Stage 2 LPFP | 93 Octane Fuel | BMS Intake | ER 4" CLess D/Pipe | ER 3" Charge-Pipe | Wagner-Tuning Competition Intercooler | Custom Turbo Inlet Pipe | https://i.imgur.com/iR4wm3I.jpg |
      02-11-2019, 01:30 PM   #77
ziekxq
I dont think it is.... you cannot even pick 550 as an option in their software/app.
      02-11-2019, 02:59 PM   #78
badblack550xi
badblack550xi's Avatar
they don't care about us!
      02-11-2019, 04:42 PM   #79
AZ_Bmw_550
Ugh, I feel marginalized...
      02-14-2019, 10:04 PM   #80
ziekxq
Even without the flash the car does go into 8th gear for me when crusing around 45-50mph speeds. When I want to accelerate the kickdown happens and there she goes lol. But with flash the kickdown is much quicker and it downshifts to a better gear where power picks up immediately vs stock.
      02-15-2019, 12:07 AM   #81
_GW_
Drives: F10 535i xDrive
For those who like charts. Here's how the xHP tune compares to the stock transmission tune for the ZF8HP on a 335i.
Found at:
https://bmw.***********.com/threads/...detailed.4252/
      02-15-2019, 06:38 AM   #82
Surly73
Just FYI for all:
I've been chatting with them because my car does not have DEC (COMFORT/SPORT switch). I don't believe they explicitly designed maps for this, but I've sent them some logs from my TCU and they've said they'll work on something.
For me I would probably be going Stage 2, and would take Comfort/D in D, Sport/S in S and Sport+/M in M put together as a "no DEC" section.
Has anyone without DEC tried xHP?
      02-15-2019, 07:29 AM   #83
ziekxq
Just FYI for all:
I got it and I am on stage 3.
      02-15-2019, 09:48 AM   #84
Surly73
So, without DEC, what behaviour have you seen in D, S and M? As I mentioned, I would think that sensible behaviour would be to map Comfort with D and the sport modes with S and M.
      02-15-2019, 10:30 AM   #85
ziekxq
D is much more fun almost as if I am in sport mode with short gear ratio. S mode shifts super quick plus keeps rpm in the range where power comes almost immediately. Manual mode is so.much fun now why, well, because now when you pull the lever down to change gear, it does it immediately. Before I would pull the lever down to change gear and there would be a delay and that delay is gone. Shifts are on point, plus increased line pressure is another reason to get it if you tuning your car.
      02-15-2019, 11:18 AM   #86
Surly73
Good to know. I'm looking at stage 2. I want a more engaging driving experience and I miss my 6MT. The stage 3 description talks about tuning for "track" and "roll racing" and always keeping the revs high in S. Not interested in that.
      02-15-2019, 11:21 AM   #87
ziekxq
I did not see revs that high between stage 2 and stage 3 in S mode. I think they referring to sport+ mode.
      02-16-2019, 11:34 AM   #88
trialmountain
Drives: F10 N55 - EWG
Does the XHP tune keep the revs in the sweet spot of the powerband? For example most 1/4 mile guys short shift short around 63-6800 as the stock turbo drops off and is less efficient up top. I don't see the need to run to redline for 90% of my driving unless I'm trying to hold it in gear through a corner and then I would be in M mode and a flash wouldn't assist me there.
2015 F10 535i | BM3 STG 2 91 Octane | VRSF 4" DP | GPlus FMIC | Eibach SwayBars | H&R Springs | NGK 97506 .020"
