2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications N55 F10 Split Second PI Controller issue
      12-05-2019, 05:42 PM   #1
jayster0966
jayster0966's Avatar
Drives: 2011 535i
Hello everyone!
Need help with the port injection wiring on my 11 535 F10. According to everything I can find, I am supposed to wire the (yellow/black) wire of the controller to pin 9 of the OBD2 port to be able to obtain tach/rpm signal so that the controller knows what RPM we are at, but I get no signal at all when checking inputs with the R4 software. Green wire to yellow wire on TMAP works properly as i can see the boost pressure fluctuating.
Is there anyone out there who can help in giving some suggestions what to do next?
Is there another wire/place I can get RPM signal from?
Any advise would be appreciated.
TIA - Jay
      12-05-2019, 07:12 PM   #2
Stück
Stück's Avatar
Port Injection is a dead platform, especially true to N54's and N55's with the early style continental HPFP.
Purchase and install a Spool Helix 3x drive, no bull shit ancillary equipment to rely on or deal with setup. It just works, and maintains 100% DME control of fueling.
      12-05-2019, 10:09 PM   #3
ziekxq
Drives: 2011 535i xDrive
Yup get that and you can run 100 percent E85 which is capable of 600whp... That enough power for stock n55. No fuss no mess figuring out how much mixture you want... But you can mix and get up.to 700/750 whp.
