2010 2011 BMW 5 Series Forum F10 how to measure coolant level on N63TU 550i (2016)? |
11-25-2019, 02:49 PM | #1 |
Rep 342
So I got a low coolant error and bought a gallon of zerex G48 premixed coolant to top it off. The first problem I had was locating the fill for the radiator. At first I added to the coolant bottle in the front center as it was showing a little low, but later I got the low coolant level again. Apparently this is only for the air/water inter-coolers for the turbos.
Then I looked online to try and determine where to add radiator coolant, but the pics/video I found for a 550i showed a coolant tank in the drivers side front corner behind the headlight. My car does not have a tank there (only what appears to be a computer module, which interestingly enough has cooling lines going to the inter-cooler reservoir). I noticed another high pressure cap on the inside fender near to the brake cylinder and after opening it had to guess that this was the radiator overflow reservoir. I ran the car with this cap off and saw coolant circulating, but there is no indicator for level. I added about a pint, with it running and turned on the heat inside and kept it running until it warmed up to about 150F. I kept adding coolant mix until it reached a flat "ledge" I saw inside the tank (might be a level marker?) and then buttoned it up. Have not received another low coolant error, but when I checked it again yesterday, it was several inches below where that little flat area is and I am wondering if I should add more coolant mix? It really sucks that BMW/manual does not support something as simple as adding coolant to your car... |
12-02-2019, 07:52 PM | #4 |
Rep 342
Nope. Was not aware of that website. Thank you.
Found: Adding coolant: Cooling system must be filled with a vacuum filling unit only! Use only recommended coolant. Observe mixture ratio. Observe filling capacities. There is a slightly complicated venting procedure, then it shows a diagram of the filler neck and has the text: When the engine has cooled off, check the coolant level and adjust it to (A) approx. 150 mm below the upper edge of the coolant filler neck. Use a tape measure where appropriate. How stupid is that? Use a tape measure to check the level... I am not impressed with this level of German "Engineering" and I'm an Engineer... |
12-03-2019, 04:27 PM | #5 |
Rep 183
Drives: 2015 BMW 650i GC
Yep, it's the only car I've ever owned that requires a tape measure to install coolant. Very DIY friendly...
12-06-2019, 01:10 PM | #6 |
Rep 470
I'm confused. Is there no overflow reservoir on these cars?
Current mods
Rockford Fosgate P3 // JBL MS-A5001 // MiniDSP Ultra Racing Strut Brace // AFe Pro Dry S // PS2 // Custom Inlet // DV+ // FTP Boost Pipes // VRSF Race IC // VRSF Downpipe // ECUTek Protune @ 5280' |
