2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Navigation, iDrive, Audio, Video, Bluetooth, Phone, Coding Aux vs USB vs bluetooth
      12-31-2013, 06:46 PM   #1
combatbmw
Drives: 20' X3M CP
Is it me or is Aux the best sound quality?
I noticed a big difference when music is playing from aux vs blue tooth or even USB.
Problem with aux is no idrive control.
Any work around?
2020 X3M CP - IND Reflector set | Ceramic Tint
Retired:2015 M5 CP MSR Intake|Carbon Fiber Fender Vents|Meisterschaft GTC catback with LXR mid pipes and ER Catless DPs | BPMSPORT Stage II Tune | RKP Rear Diffuser and Challenge Center piece |RKP Front Lip| Painted Reflectors | H&R Springs | Strasse SM5R Carbon Fiber Wheels | Nitto R888 |
      01-06-2014, 06:37 PM   #2
B33M3R
B33M3R's Avatar
Drives: F31 335d XD M Sport
Not technically possible, aux is analogue v digital signal over the other two, albeit compressed over the Bluetooth. Not doubting you prefer aux though.
How's it sounding better? Can you elaborate?
      01-07-2014, 02:32 PM   #3
combatbmw
Drives: 20' X3M CP
Try it, AUX sound is louder then bluetooth and usb.
You dont have to turn the dial up as much to hear.
with pandora and usb I litterally have to max it out for it to be really loud.
Aux half way is just as loud, and all the way up is beyond loud.
      01-07-2014, 03:23 PM   #4
B33M3R
B33M3R's Avatar
Louder it may well be, louder does not equal better sound quality!
      01-13-2014, 04:12 PM   #5
EmArAsOnS
EmArAsOnS's Avatar
Sweden
13
Drives: LCI F11 MSport Xdrive (I.Blue)
      01-13-2014, 07:17 PM   #6
mlai
mlai's Avatar
Hong Kong
170
Drives: 650GC/E93M3/Lexus LS600HL
Sound quality depends on a lot of different things, and the source actually plays the most important factor. And from our local F10 gatherings, we have the same conclusion that AUX sounded best, provided that you have a great audio source.....
Put it simply, for CIC systems, the best quality is limited at CD quality, or WMA Lossless at 44.1K/16bit. NBT systems are limited at FLAC 96K/24bit which are HiDef(have not tried 192K/24bit yet....) Both systems MAYBE able to play DVD-Audio, which are higher quality than CD.
However, that's only one part of the equation. If you rip CD into the hard-drive, it will get compressed, most likely to MP3. If you import, the music most likely will just get copied onto the hard-drive.
Most of these compressed music will have to go thru decoding, and internal DAC and this is where it matters a lot! The quality of the DAC of the CIC/NBT units are just not comparable to real HQ DAC units like Astell and Kren AK100 or AK120s. With music stored on AK120, and played via AUX, you will get way better resolution of the sound, provided that you have really high quality music sources (192k/24bit) to take advantage of that. Playing the music via AUX bypassed all those DAC in the BMW audio system, and thus bypassing any audio inefficiencies introduced by the onboard digital system......
F06 650i Gran Coupe Ruby Black/Dakota Cinamon- 2012-10-12 Adaptive Drive/IAS/Surround View/Adaptive LED/Comfort Seats/BMW 356 Liquid Black/Michelin PSS 245/35R20-285/30R20
E93 M3 Cabriolet Satin Pearl White/CR - 2012/03/12 Bilstein PSS10/ Michelin PSS 245/35R19-265/35R19 Brembo GT
2011 F10 550i M Sport - Retired
      01-14-2014, 07:30 AM   #7
EmArAsOnS
EmArAsOnS's Avatar
Sweden
13
Is that the case with B&O or KH as well?
(Source 320kbit/s? Or less?
      01-17-2014, 01:38 PM   #8
B33M3R
B33M3R's Avatar
The OP considers his Aux in sound quality to be better than his USB or bluetooth connection as to him it is 'louder'. The AUX in is going to be affected greatly by whatever is plugged into it, the volume it is set to and the EQ settings of the device attached are all going to have an effect.
When played back to back with either of the other two inputs it most certainly could mean 'aux half way is just as loud'
I accept that there are going to be better DAC's available than within the BMW audio systems but I think you're kidding yourself if you think you're going to achieve better sound quality via that route.
Also, I seem to recall the AUX in has both capacitors and resistors inline to reduce static and voltages which could damage the idrive. These are also reported to knock out frequencies at both ends of the spectrum.
F31 335d M Sport XD - Mineral Grey - Coral Red - 19" 442M - HK Audio - M Sport Plus Pack - Heated Seats
Check out my E90stereo install guide - http://www.e90post.com/forums/showthread.php?t=540954
      01-20-2014, 09:38 PM   #9
ezmaass
ezmaass's Avatar
Drives: '17 650xi GC / '15 Audi R8 V10
The aux input may sound louder, and even "better," if the device you have plugged into it has EQ settings that are superior to those set in the car. For instance, on my phone, I have the EQ customized. On the 550, I've yet to even play with EQ. Many phones these days may even apply certain EQ settings as soon as they detect headphones (line-in).
I would play with the EQ on the car stereo after you plug in your digital source (USB). I would imagine that USB will absolutely sound the best in the end after some customization via EQ... it's digital vs. the analog source from your aux socket. Bluetooth, while "ok" will never be as good as the other two, I believe, simply because the audio needs to be greatly compressed.
2017 BMW 650xi Gran Coupe | MSport | Exec Package | Driver Assist Plus | ACC Stop & Go | Adaptive Drive | B&O | Night Vision | Cold Weather | Active Seats
2015 Audi R8 V10 | Brilliant Red on Black | S-Tronic | Carbon Sideblades | Carbon Trim | Full Leather | Sport Exhaust | Illuminated Doorsills | I-Pod | Contrast Stitching
Previous: '14 550xi, '07 335i, '01 325i
      01-21-2014, 08:53 PM   #10
mlai
mlai's Avatar
Hong Kong
170
I encourage you to do the following experiment:
1) Find a good copy of Hotel California, and also a piece of orchestra performance in 192k/24bit flac.
2) Put one in a USB, and one in a AK120.
3) With eq flat on both device, do a back-back comparison.
4) Adjust eq on the car to try and "optimize" the sound.
We did this on 20 F10s (both CIC and NBT,hifi loudspeaker professionals= with CIC only able to play WMA lossless at 44.1/16bit), my E93M3 (HK sound), and my F06 Dirac. In blind testing by all the respective owners, every single one agreed that AK120 resulted in more clarity than the USB direct to NBT and CIC.
We had a stereo shop owner and technician join us at the blind testing as well, and he had the same conclusion.
All I can say is, start with a very high quality source, and then you can really tell that the DAC plays a very important role. However, if you are just using CD source, or ANY compressed music formats, don't bother.
PS. Louder does not mean better.....
      02-19-2019, 01:41 PM   #11
silverfoxS65
silverfoxS65's Avatar
12
Drives: 2008 E90 M3
2014 BMW M5  [10.00]
@mlai
I have a question - I'm not really looking for louder - but better audio quality
Currently on my B&O system - when using BT I can hear the bit rate or quality going up and down
The source is a iPhone 8 Plus on latest iOS
The player is Spotify downloaded playlists set at the HIGH setting which the app states that it should be downloaded at 160 bit/s
Ive even tried it at Very High which is 320 - and same result
Am I missing something? A setting or update I need to make to my car or phone?
This has been bugging me for a while
2008 Silverstone/Fox Red M3 sedan - daily
2003 Space Grey Metallic E39 M5 - Sold
2014 Sakhir Orange F10 M5 - sold
      03-03-2019, 03:31 AM   #12
JasonFH
Drives: 2015 535D
Originally Posted by thatorangem5 View Post
@mlai
I've been researching BT a lot lately. Apple defaults to the AAC Bluetooth codec. It's a variable bititrate codec, based on signal quality. (one would think within the car this wouldn't fluctuate much, and be a solid signal, but who knows). I'd venture to guess that's what you are hearing. Android uses a more common SBC codec and has options for several other higher quality codecs like aptx or LDAC. In my f10 with the Harmon Kardon system I can only use SBC or AAC though and in my ears, SBC sounds better. It would be great if we could get Ldac or atx HD in the bimmer. Your best bet may be through USB or aux input.
This was a helpful article.
https://www.audioholics.com/audio-technologies/bluetooth-audio-guide/
      04-05-2019, 05:39 PM   #13
p3ernie
Drives: 2019 530i
In my previous F series, I had a Mosconi Bluetooth Module connected to a DSP, Mosconi amp, and Gladen extreme speakers. I would connect my phone's media bluetooth directly to Mosconi, and the mosconi bluetooth module had a built in dsp that would send the signal to the amp and dsp that made the sound SO much better than aux, usb, or stock bluetooth. The only thing was that my phone did not always connect automatically to it so most of the time I had to manually connect every single time I was in the car. This was a major pain in the ass but the sound quality was so worth it. I now have a 2019 530i HiFi and the sound is so terrible. I am debating on going back to the Mosconi and Gladen setup. If my phone could autoconnect to the mosconi as easy as it does to the bmw bluetooth, I would do it in a heartbeat.
