09-17-2022, 12:45 PM | #2686 |
BMW enthusiast since 2004
62
Rep 85
Sport/comfort button retrofit.
jayster0966204.50 |
09-17-2022, 03:12 PM | #2688 | |
62
Rep 85
Heated steering wheel, sport shifter I did earlier on F10. ![]() |
09-17-2022, 07:04 PM | #2689 | ||
![]() ![]() 342
Rep 1,151
09-18-2022, 04:35 AM | #2690 |
62
Rep 85
B&O must a heck of job. I only got S676 but it's fine for me. Acc is only thing I miss... And maybe ventilated seats that I have on e65 also.
09-29-2022, 01:21 PM | #2691 |
62
Rep 85
Removable Tow hitch installed. Next step is to do the wiring.
StradaRedlands1162.50 John H.204.50 |
10-03-2022, 01:02 AM | #2692 |
![]() ![]() 59
Rep 75
Drives: 2015 BMW 535i M Sport
Detailing Day & first time ever using ceramic coating instead of wax.
All by hand (no buffers). I compounded & wax'd a year ago so I skipped and used a polish instead. Products Used: Gyeon Q^2 MOHS EVO Ceramic Coating Gyeon Quartz Prep Chemical Guys P4 Precision Paint Perfect Polish Chemical Guys Clay Bar (Light-Yellow) & Luber Dawn Dish Soap (I apologized to my car first) Various microfiber towels, suede for ceramic application I didn't get a chance to take a full set of pics yet but here's a quick one I snapped to give an idea of the shine achieved. Hoping to take the "money shot" pics tomorrow (from front and slightly to side, imo, is the F10 best profile) |
CrippledLucifer99.00 StradaRedlands1162.50 |
10-03-2022, 11:11 AM | #2693 |
![]() ![]() 115
Rep 152
Drives: BMW 535i F10
Installed the CF eyebrows on headlight
10-03-2022, 01:01 PM | #2694 | |
![]() 626
Rep 1,094
Looks awesome!!
ctcarbonari58.50 CrippledLucifer99.00 |
10-27-2022, 01:06 AM | #2695 |
![]() ![]() 1163
Rep 1,036
Drives: 2006 BMW 330i MT
I was showing a bad ignition coil, so went ahead and swapped them all out. Easy 45 minute job starting from walking in the door after work and ending with closing the hood and locking the car when done. Dealer quoted $1,500 for the job... wow! Soooo much easier than my E90 which needs the air filter contraption moved out of the way to access the last two. This was just a pleasure to work on! Didn't even require tools other than a 10mm socket to remove the engine trim cover, and a small bracket covering coil #6 I had to move out of the way. 115k miles on the clock, so it was time.
11-02-2022, 02:23 AM | #2696 |
![]() ![]() 1163
Rep 1,036
Broke down and took to Ontario BMW for service. Throwing codes for water pump and alternator, and previously oil level sensor, so concern that it was the BSD and/or DME. But they decided it was the aftermarket alternator the previous owner put in to save a couple bucks. It was not playing nice with the system, and was causing the other codes. So water pump was fine, and the previous oil level sensor was probably okay as well. So this round ended up costing me a mortgage payment worth of new alternator! Frustrating as I could have done it myself (four bolts FTW!) but I really wanted it tracked down. If that didn't fix it, would probably end up selling the car and taking a huge financial hit. But fingers crossed, it seems to be fine! I drove it to work for a couple days, and spouse is back in it and as happy as can be... she loves that damn car!
Next big expense will be when the adaptive suspension struts/shocks need replacing... those pieces are EX-Pen-SIVE! Doesn't need them yet, but know it's coming down the bend. Right now I just want to go a month without needing to put one to two thousand dollars into a vehicle! |
11-15-2022, 09:36 AM | #2697 |
![]() 24
Rep 75
where did you get your lip? Hard to tell from pic but is it flat/primed black?
2016 BMW 550i M Sport - Mineral Gray Metallic
2015 BMW X5 base - Jet Black 2011 BMW 335i - Alpine White Last edited by SummerallGuard04; 11-15-2022 at 03:16 PM.. |
11-15-2022, 09:37 AM | #2698 |
![]() 24
Rep 75
Decided to give the popped leather dashboard the 'ol college (DIY) try:
PICS below vvv https://f10.5post.com/forums/showthread.php?p=29545582
2015 BMW X5 base - Jet Black 2011 BMW 335i - Alpine White |
11-20-2022, 01:45 AM | #2699 |
![]() ![]() 1163
Rep 1,036
Oil filter housing and oil cooler gaskets getting done today! Old ones were just starting to weep at 115k miles/11 years. They were still a bit supple, but were going, going... almost gone. Scraped off the old gasket residue and put it all back. Only real drama was that damn accessory belt. Could not get it back on. Then poof, went on fine. Not sure what changed, but glad it did!
ctcarbonari58.50 r2dmax52.50 |
11-23-2022, 02:17 PM | #2700 |
62
Rep 85
New intake manifold and plastic water hose flange for head. |
11-26-2022, 03:28 PM | #2701 |
Rep 3
Added a 12.3 inch screen with CarPlay to a well maintained 2013 535i GT M-Sport.
11-28-2022, 01:05 AM | #2702 |
![]() ![]() 1163
Rep 1,036
Replaced the crumbly old cowl and a shiny new one! Easy job that I bought a wiper arm puller for. Only little complication was the wiring and fluid line in the right corner that had to be disconnected. What a difference!
Old one lifting off and falling to pieces: ![]() Comparing the two: ![]() Easy to disconnect, just a little hard to access: ![]() Et voilą: ![]() (really is flush, photo just makes it look like it's puckering up) |
ctcarbonari58.50 |
11-28-2022, 04:12 PM | #2703 | |
![]() ![]() 2479
Rep 4,605
Nice job! Part number? |
11-28-2022, 08:09 PM | #2704 |
![]() ![]() 1163
Rep 1,036
Best $100 I've spent all month! 51717203124
ezaircon4jc2479.00 |
12-16-2022, 09:32 PM | #2705 |
![]() ![]() 1163
Rep 1,036
My OCD got the best of me and I just had to get a proper replacement for the blower cover filter. I still think my netting was pretty good, but I bet the factory one is better. Hopefully it will last another decade like the previous one did!
cdmulders272.50 |
12-17-2022, 11:20 PM | #2706 |
![]() ![]() 53
Rep 139
Drives: F10 535i xDrive, E82 135i 6MT
