2010 2011 BMW 5 Series Forum F10 All door locks no working |
01-11-2017, 12:27 PM | #1 |
Rep 24
Yesterday after returning to my recently locked car, my driver's door lock wouldn't open even with a double exterior handle pull. I realized that when locking and unlocking the car the passenger doors locks where staying up. The lights would flash and the horn would beep as usual.
I was able to open the drivers door with the mechanical key. The driver's door will lock on command but not unlock without the mechanical key. I manually pushed the other 3 door locks down and they havent unlocked since. The car starts up fine so I doubt its the car battery. I've read of single door actuators failing but all 4 at once is too coincidental. I also read that weak key fob battery can lead to soft touch feature problems but if the car receives the remote signal or if the interior central lock button is pressed, I'm not sure how the FOB battery plays a role. I plan to change them shortly anyways. Any other things I should check? Any particular fuses that have been known to cause this when blown? There are 10+ door lock fuses listed and the ones in the glovebox are going to be fun without the passenger door open.... Thanks in advance! Panos 2011 535i Msport |
01-16-2017, 01:52 PM | #3 |
Rep 24
Yup that was it! A slight pain to reach that fuse without the passenger door open. So just change the fuse and leave it? usually fuses dont blow for nothing. Should i be looking for the slow door lock button and change that actuator before it seizes and while I can still open the doors?
EL Jeffe 5612.50 |
01-17-2017, 01:33 PM | #4 | |
Rep 130
01-17-2017, 01:46 PM | #5 | |
Rep 24
EL Jeffe 5612.50 |
01-17-2017, 04:23 PM | #6 |
Rep 130
04-05-2018, 06:27 PM | #7 |
Rep 1
Door Lock Fuse Repeatedly Blows
I had this issue and was able to get my locks to work after replacing the 15 AMP fuse in the glove box. After the first time, they worked for another 4-5 months; however, I have now replaced that same fuse 3 times in the past week. Did anyone else have continuing issues with this? If so, were you able to pinpoint the issue? I have been reading and researching anything I can find on the internet to try to solve the issue myself. I am thinking I may have a short somewhere in the wires, possibly the ones in the driver's door leading to the locking mechanism, and I have read that maybe I just need to cover them with electrical tape. I just don't want to take apart the door panel if there is an easier fix or other possible reason that there is a surge in electricity that is causing my fuse to blow.
04-06-2018, 01:13 AM | #8 |
Rep 697
Drives: 2013 535xi
As some other threads have explored, your similar problems are very likely a sticking lock actuator. When sticking, the actuator could draw too much current and blow the fuse. I have a sticking actuator right now too, but have not got around to having it replaced yet.
2010 Z4 35i, Crimson Red, beige interior, 6sp manual, Adapative Suspension 2000 528i, Cosmo Black, beige interior, Sport package (retired) |
04-25-2018, 11:40 PM | #9 |
Rep 170
Yes, my passenger door actuator went out which caused the fuse to go out. If you have to replace the fuse continuously the actuator will go out. Just a matter of which one.
06-10-2018, 04:04 PM | #11 |
Rep 5,378
When my right rear actuator went out the door (lock) worked mechanically just wouldn't lock electrically. As long as the door was unlocked it worked fine.
06-15-2018, 03:42 PM | #12 | ||
Rep 1,684
06-15-2018, 04:29 PM | #13 |
Rep 385
It should open just by pulling the inside door handle twice, once to unlock and second should open the door. You can relock by pushing the button down.
06-15-2018, 04:35 PM | #14 |
Rep 385
It's pretty typical to replace several lock solenoids on bmws if you own them for more than a few years. It seems to have gotten better in the 5s since e60 but this is no surprise to me.
If you figure out which one is in trouble, just replace it or get it replaced. |
07-04-2018, 04:28 PM | #15 |
Rep 14
I had a similar problem that started with the front passenger lock not unlocking. It went from that door to no door locks working. They fixed that with a fuse(not sure which one) in the glove box. 2 days later, the front passenger lock wouldn't unlock again. The dealership replaced the front passenger door lock actuator.
That seems to have fixed the problem for good. Good luck. Darren
2014 F10 535d M Sport
Alpine White |
07-04-2018, 05:36 PM | #16 | |
Rep 1,254
my guess is bad design
07-05-2018, 09:12 AM | #17 | |
Rep 1,873
Locking from the central lock button while in the car is a "single lock" and the doors can be opened from the inside with a double pull. Locking from the remote and arming the alarm is a "double lock" and the doors will not open with a double pull from the inside. When "double locked" the actuator and lock mechanism rotate a different amount in a different direction and it disconnects all of the rods and bowden cables so they can't be snagged with a slim jim to open the door. So - if you're having any issues with door lock actuators - don't wait. |
07-05-2018, 09:14 AM | #18 | |
Rep 1,873
If you've got a slow actuator I would at the very least open everything and try to DIY some lubrication if you're out of warranty to see if it helps. |
07-06-2018, 08:22 AM | #19 | |
Rep 1,254
07-06-2018, 10:14 AM | #20 |
Rep 1,873
I told them one actuator was visibly slower than the rest, and was even more pronounced in cold weather. That's all it took.
EL Jeffe 5612.50 |
08-28-2018, 06:40 PM | #21 | |
Rep 1
I have same problem
Hi Surly I have same problem in my (BMW 523i 2011), its appeared when i did not use the car and stopped for a whole month without work, the battery ran out and this failed. I did jumpstart, first time from the jumpstart point and the car get running but the battery didn't recharged again, and i noted that the central lock does not work. I went to BMW service center and replaced the battery and reprogramming the car but problem still, and they said in the service center at first you maybe have to change the (Control unit, central gateway module), and after recheck it again they said you have to change the actuators for all doors, so - Do you think i have to change actuators? - What is the reason behind the failure of all actuators together ? Many thanks Last edited by Samuel85; 08-29-2018 at 09:19 AM.. |
05-18-2019, 02:04 AM | #22 | |
Rep 1
I have the same issue with the same car model 535i - 2011 all you have to do is to change fuse No. 14 (15 Amp) the fuse is located inside the glove box in-front of the passenger's seat. |
